Whitejames: Can you clarify what you mean when you mention the fuel delivery felt more precise in the GTI compared to the R? Not sure I follow that point
Service Training
Self-Study Program 824803
The Volkswagen 2.0 Liter
Chain-Driven TSI Engine
Fuel System
38
High-Pressure Regulation
Fuel pressure and fuel quantity are regulated by Fuel
Pressure Regulator Valve N276. The signal from Fuel
Pressure Sensor G247 is used by the engine control
module as a parameter. This sensor is located in the
fuel rail.
Power demand has been reduced signifi cantly
through a newly designed fuel pressure regulating
valve and associated control concept.
At the start of delivery, Fuel Pressure Regulating
Valve N276 is activated only very briefl y. The intake
valve closes, fuel pressure builds up, and fuel
delivery immediately begins.
High-Pressure Pump
The demand controlled high-pressure pump by
Bosch is driven by a four lobed cam on the end of
the intake camshaft.
The pump piston is driven by the camshaft and a
cam follower. This reduces friction as well as the
chain forces. The results are smoother engine
operation and higher fuel economy.
The use of the four lobe cam has allowed a reduced
piston stroke compared to earlier versions of the
2.0L TSI engine. Due to the shorter stroke, the
individual delivery rates are lower. This, in turn,
results in reduced pressure fl uctuations. The
metering precision of the injectors is also improved,
as there is now one feed stroke per injection. The
advantage of this is improved oxygen sensor control
and fuel effi ciency.
The high-pressure pump produces a maximum
pressure of 2175.5 psi (150 bar). The fuel pressure
requested by the engine control module is adjusted
by Fuel Pressure Regulator Valve N276. The pressure
is regulated between 725.1 psi (50 bar) and 2175.5
psi (150 bar) depending on engine requirements.
The high-pressure pump now has its own pressure
limiting valve. This valve opens at approximately 2900
psi (200 bar) and admits pressure into the pump
chamber.
Previously, pressure was discharged into
the low-pressure circuit. Excessively high-pressures
can build up in overrun or when the engine heat
soaks after shut-off.
The pressure pulsations in the low-pressure circuit
are reduced by a damping element integrated in the
pump.
Fuel System
38
fuel rail.
High-Pressure Pump
chamber.
pump.
The above information is from a technical self-help guide for Audi tecnicians.
I saved a copy of this guide as I was interested in researching the cam follower issue on the EA113 -v- EA888 motors.
The four lobe cam of the EA888 gives greater precision in fuel delivery with each throttle application - improving fuel consumption & consistency in throttle repsonse.
The four lobe cam - fuel actuator is an improvement similar to the introduction of direct injection, but in a different area of the motor.
The remapping of the throttle is related to the software ECU tune of the motor.
The four lobe cam of the EA888 relates to a hardware improvement.
It's unlikey that a remap ECU tune will totally eliminate that fact that the EA113 motor does not have a four lobe camshaft - fuel follower actuator hardware upgrade.
You're welcome to put forth your opinions on each vehicle.
Healthy debate is encourgaged.
WJ
.... no amount of justifcation will get you past those 2 fundamentals ....
