Originally posted by logger
View Post
I would start with:
031,1,Lambda Control,Bank 1 (actual)
031,2,Lambda Control,Bank 1 (specified)
This should give you the target value and achieved value. If pulling a raw sensor reading then you should take the one before the catalyst which would normally be sensor 1.
In combination with the RPM, manifold pressure and ignitiion timing info you have already identified it should give a pretty good indication if any significant changes to maps have been made. Theres some other interesting data there on the knock sensing but its going to be impossible to interpret the readings unless we had access to the interface spec for the sensor.
I assume that you will wait until the coolant temperature has stabilised and try to repeat the test at a equivalent ambient temperature.
