Mine's a Jan 10 build and apparently needs the update as well.
1 of 2
2 of 2
Golf 118 TSI Engine Failures and Service Campaign 24S4
Getting my ECU reflash done in the next couple of days.
Anyone got any good suggestions as to to what I should record beforehand with VCDS, so as I can ascertain what has changed afterwards.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Originally posted by logger View PostGetting my ECU reflash done in the next couple of days.
Ideally you would keep a copy of your original file and then compare it with the recall version, you'd need to have some way of getting yourself a copy of that though. I can do the map comparisons but thats of little use to you down there.
Should be able to grab mist of those and easy enough to save them to a file. I can record from 1 to 12 parameters simulataneously. Only issue is the more I grab the slower the sample rate. So might only be once very 2 secs with all 12 being logged.
I was thinking of grabbing:-
002,1,Engine Speed,(G28 ),Specification (Idle): 680...730 RPM
002,2,Engine Load
002,3,Injection Timing
002,4,Intake Manifold,Pressure (G71)
003,3,Throttle Valve Angle
003,4,Ignition,Timing Angle
112,1,Exhaust Gas,Temperature Bank 1
241,2,Boost Pressure,(actual)
Can you take a quick peek at tsi.txt and tell me what group will give Air Fuel Ratio?
Keep in mind I can only grab 12 at a time max.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
So what happens to pepople who have got an aftermarket ecu tune?
Would the aftermarket tune prevent the engine failures as it has already been remapped for different variables?
Or would you have to get the dealer remap and then re-flash the ecu with the aftermarket tune again?
Originally posted by team_v View PostWould the aftermarket tune prevent the engine failures as it has already been remapped for different variables?
Originally posted by team_v View PostOr would you have to get the dealer remap and then re-flash the ecu with the aftermarket tune again?Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Originally posted by team_v View PostSo what happens to people who have got an aftermarket ECU tune?
would you have to get the dealer remap and then re-flash the ECU with the aftermarket tune again?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
You would need to know exactly what the VW retune does to know for sure. You would think that most tuning companies would be looking at it pretty closely to make sure if they need to revise their maps they do.
Have their been any cars with aftermarket tunes suffer similar engine failures?
FOLLOW US ON FACEBOOK
Originally posted by team_v View PostSo what happens to pepople who have got an aftermarket ecu tune?
Originally posted by Guy_H View PostAlready had some APR cars that have had the factory reflash done, no problem to re do the APR with the updated VW specific code once you have had the VW work done!
Which all ties in with the VW "fix" modifying something unrelated to what the tuners tune. Have just got myself an 10 minute Pre-fix log of numerous parameters. Cold start through to near max boost. Will be interesting to compare it with an afterwards log to see what, if any, changes are visible. I still have a hunch the issue is not where everyone around here is looking, and will report back if it turns out to be the case.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Originally posted by logger View PostGood Point, although you'd think they would only contact that batch of owners if that was the casel.. But might as well add it.
A few questions for those who had TSI engine failures:
How Many KMs?
Do you mainly do a lot of short trips?
Do you mainly do fewer longer trips?
Do you alway drive in a gentle manner?
Do you flog the car and give it a bit of a hiding from time to time?
Do you only use 98Ron fuel?
What is your car build date?
How Many KMs? 9000
Do you mainly do a lot of short trips? Yes
Do you mainly do fewer longer trips? No
Do you alway drive in a gentle manner? No
Do you flog the car and give it a bit of a hiding from time to time? Yes
Do you only use 98Ron fuel? Yes
What is your car build date? 07/092009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
Since the fault happen in such a short time from new, I would also ask the question about how the engine was run in? But as logger said, who knows what causes it?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Originally posted by Tim View PostYou would need to know exactly what the VW retune does to know for sure. You would think that most tuning companies would be looking at it pretty closely to make sure if they need to revise their maps they do.
Have their been any cars with aftermarket tunes suffer similar engine failures?Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
its all speculation at the minute. Be good to hear some accurate info to base opinions on.
Yep, my speculation would be that it is a bad badge of pistons or pistons not suitable for application and VW fix (at least for now) is to downtune the engine a bit.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
