15,000km Service Cost from Each Dealer Outlined
  • 1st Service and Firmware Updates
    Hi,
    I have a 2011 Mark 6 Golf and its due for its first service (15,000km).
    I have a shop around and the Volkswagen Dealers in my area (Brisbane) quotes around $430 - $480. From what they told me, its just a filter and oil change + any firmware upgrade.
    I called a few other garages and they will charge around $170 - $250 for filter and oil change. So my question is, is the firmware update necessary? Has anyone tried to find out if they actually have a firmware upgrade for a car that's less than 6 months old?
    It seems a lot of money to spend... for someone to plug their computer to it and make no changes. I'm happy to pay for firmware upgrade. As long as it gets done. Not just a plain, plug in and check and nothing gets changed.
    What's everyone's thoughts? Worthwhile? Your advice/help is much appreciated.
    Regards,
    Alison
    • What firmware update are you talking about?
      Is it an ecu update or a stereo update?
      I would go to an independent service provider (prestige and performance have my car next week, although Jmac form Alba european also gets a very good rep on the forums here) and ask if they can provide the ecu update (if one has occured)
      • If there's an important firmware upgrade VW will notify you, it will be free and can be done by any dealer.
        There have been two so far on my '09 TDI.
        I wouldn't let the possibility of one influence my choice of service provider.
        • There's no guarantee that there is or isn't a software update. It's just part of the general servicing checklist to check for any updates and install them if found. This could be for the ECU, DSG, or RNS510, maybe even the MDI (I don't know how thorough they are).
          So far I've been getting the minor (15/45) services done at the expensive dealers to keep up to date, and then getting the major services done at an independent VW specialist.
          This checking for updates doesn't cost the difference in price between their quote and other garages. VW just charge a lot more for parts and labour, etc. You could get all your services done at a garage (one that updates your log book and uses genuine VW OEM parts and doesn't void your warranty) and book in a time with VW to check for updates. They might charge about $60 for this (check with them though). It then becomes a question of time v. money.
          Audi A3
          • Do what ever makes you feel right, however I just had my 15K service and did the whole independent v OEM service cost to value thought process and decided in the end to take it to VW. This was based on wanting those VW stamps in my service book, peace of mind, sleep at night sort of stuff.
            Glad I did as they found an oil leak which required a new seal between the turbo and the engine which required parts and most of the day to repair. This cost me no more that the scheduled service fee.
            Now sure everything might be fine for most but just keep in mind this is the first service, good oppotunity for the VW folk to go over your car and check that first year ownership ( which we have to all admit was pretty hard on the ol engine as we tested the limit) has not been too hard on the car post factory delivery.
            Worth the bucks in my mind
            • Originally posted by SilvrFoxX View Post
              Alison -
              I have rung around today as the dealer closest to me (northstar) wanted $486 for a 15k service. After some minor foaming at the mouth, I phoned norris (440) and highway south ($405) and finally garry crick up the coast (320)
              Needless to say, I booked it in at gary crick. Happy to spend an hour of my time driving up and back from the coast to save $166.
              Unreal...
              • Originally posted by warped_foobie View Post
                Alison -
                Unreal...
                Why not use Presitge and Performance or Alba European.
                I ended up with $270 for the 1 year/15k service from P&P
                • Originally posted by alibaba View Post
                  Hi,
                  Please...you spent 40+K on a car and want to go cheap on servicing it???
                  Around $400 at a dealer is about right. VW specialist probably charge around $300.
                  2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
                  • Thanks for the advice Fellas.
                    • 15000 Service
                      My car is a 2011 Golf 118 TSI 7 speed auto,
                      15000 sevice today at Hunter Volkswagen at Maitland. Cost $321 , supprised with the lower cost as they appear to be a upmarket dealer.
                      I was advised when i dropped the car in that they would carry out a 37G7 transmission opdate.
                      I mentioned that there is an occasional slight shudder when going from first into second gear. When driving to home there was no change to the occasional shudder, it is still there.
                      I also advised that the compartment in front of the gear leaver was not always latching when closed. They have orded the part and will be replaced.
                      They have given a comprehensive list of work that was carried out, and i am very happy with the service,
                      • I believe the shudder is a mechanical issue, not a software issue.
                        Be sure to mention it to them when you return to have the storage compartment replaced.
                        '07 Transporter 1.9 TDI
                        '01 Beetle 2.0
                        • just had my 15 thousand km service on the R done at Gold Coast Volkswagen.. $395. Really good customer service, kept in contact with what was going on (I reported an issue with front brakes - turns out the callipers weren't lubed from the factory so the pad wasn't completely making contact with the rotor) - was making a slight squeal under light braking..
                          I weighed up going to the private VW specialists 5 mins away.. (VAG in southport) .. they wanted $340.. so for the extra $50 I'd rather get it done with the dealer and get the VW stamp in the book. i thought private would be around the $250 mark but appears i was wrong.
                          nom nom nom
                          • Just had GTI 15K serviced at barlow world fivedock sydney. Total cost $365 (under fleet discount) included rotation. They also had a look at some rattles and squeeks in the car and fixed them too. Daniel from their service department is really knowledgeable. Asked him a bunch of questions about the car and he explained in detail. Gino the service manager confirmed that servicing with the dealer builds up 'goodwill' and any issues in the future would have a better chance of being fixed at no cost. Also any future oil or washer fluid top up he said just drive around and they will do top up for no charge. All in all happy with the service.
                            MY12 GTI CANDY WHITE DETROIT SUNROOF - BRINGS A SMILE TO ME FACE EVERYTIME
                            • Quoted for $450 at Austral VW (Brisbane)
                              MY12 MKVI Golf GTI DSG
                              MY16 MKVII Golf 92TSI Tendline DSG
                              • Man you guys are getting ripped off majorly for servicing. If you are in the major cities, PLEASE go to an independant Euro specialist:
                                eg: Sydney - RamSpeed, Exoticars, BWA Auto
                                Brisbane - BPS Autos, Alba European
                                Adelaide - MRL Automotive
                                Melbourne - RTR
                                I got quoted $420 from VW Newcastle to do my 15,000km service. I laughed and hung up. I got it serviced at Audi down the road for $250.
