Just wondering - is there an oil/fluid in the DSG gearbox? Could it be that there's not enough/too much - that's causing the issues?
DSG: Problems, Questions, Likes and Dislikes
The revving out in neutral problem seems to restricted to the Golf R (please correct me if I'm wrong), so I'd take a punt it has something to do with the way the DSG interacts with the EA113 engine or the Haldex AWD.
Any better theories out there?--------------------------
My theory was coming from how people have said it happens when turning a corner, or changing lanes. Which I start thinking there's some sort of lateral force in action when it happens. I remembered back to this old VK bomb of a Commodore I used to own as a train station car. It would do the same thing. All the auto transmission fluid would slush to one side and the thing would basically spin in neutral until it slammed back into gear.
If the fluid in the box could be measured - perhaps the people who are experiencing the problem could find something common. (ie. Fluid level too low, or too high).My car: MY18 Arteon
My car #2: MY22 Volvo XC40 Pure Electric
Her car: MY22 Skoda Octavia Limited Edition Wagon
Mine did it again today. Pulled off the M2 offramp to Beecroft, sat at the lights for about 5 mins in 1 (M mode). Accelerated when the light changed, nothing. Looked at the dash-Gear=1. Revs=2-300rpm. Lift foot, reapply- Same thing. Shift to D-Same thing. N then back to D, all fine, but engaged with a thud. Drove off. Wish I had my camera at the ready!!!
Not sure if this helps, but I've experienced it many times without any lateral movement.Originally posted by DreamensioN View PostMy theory was coming from how people have said it happens when turning a corner, or changing lanes. Which I start thinking there's some sort of lateral force in action when it happens.
Particularly happens when going over a speed bump at about 15km/h, then as you finalise the speed bump, and roll out on to road and hit the gas as you try and get back up to 50-60km/h.. Slip!
Happened probably about 10 times now.. Only once though whilst accelerating at higher revs..2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
See - now that is a safety issue. Imagine being at a set of lights, it goes green, the car behind you is expecting you to take off. You're sitting there spinning in neutral, and they run straight up the back of you.Originally posted by ozgti View PostMine did it again today. Pulled off the M2 offramp to Beecroft, sat at the lights for about 5 mins in 1 (M mode). Accelerated when the light changed, nothing. Looked at the dash-Gear=1. Revs=2-300rpm. Lift foot, reapply- Same thing. Shift to D-Same thing. N then back to D, all fine, but engaged with a thud. Drove off. Wish I had my camera at the ready!!!
How old are the R's from people who are having this problem? MY11.5? MY11?My car: MY18 Arteon
Touch wood I haven't experienced this yet but I wonder if the way you use the accelerator could have something to do with it.
I've spent most my time driving manuals so tend to give it about 10% throttle till I feel it start to catch and then go.
Do the people who are having this problem tend to do the same or are most of you just slapping the accelerator to the floor like you would in slushbox?
I have MY11 Golf R. Had 2-3 occasions of the round-a-bout issue when DSG appears to rev out in neutral despite being in 'gear'. On the weekend I was driving along highway when it started to go between 3rd and 4th every 2 seconds and revving like mad. Nothing I could do would stop it. Had to go into manual, brake and turn car off. Started again and all good.
That actually happened to me when i took a demo for a test drive when the R's first came out. I was on the freeway and the car just starting changing up and down between 4th & 5th continuously, i had to use the paddles to shift up and stay in a gear.Originally posted by graemeshep View PostI have MY11 Golf R. Had 2-3 occasions of the round-a-bout issue when DSG appears to rev out in neutral despite being in 'gear'. On the weekend I was driving along highway when it started to go between 3rd and 4th every 2 seconds and revving like mad. Nothing I could do would stop it. Had to go into manual, brake and turn car off. Started again and all good.
Thankfully has never happened in my car and only had the issue of going into neutral randomly once.MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
Interesting! I've had the 'neutral' experience about 6 times now, the last few were in manual mode 1st gear and it felt as if I was in a manual with the clutch still engaged. This occurred on the straight and turning, I backed off the throttle, re-engaged throttle and all good. Mine's a MY11 with 6500kms. Will raise this at the 7500km service.Originally posted by graemeshep View PostI have MY11 Golf R. Had 2-3 occasions of the round-a-bout issue when DSG appears to rev out in neutral despite being in 'gear'. On the weekend I was driving along highway when it started to go between 3rd and 4th every 2 seconds and revving like mad. Nothing I could do would stop it. Had to go into manual, brake and turn car off. Started again and all good.WLF127
Touch wood, and I know this is for Mk6 Golf's, but I have yet to experience any real issues with my DSG in the 3 Passats that I have had, a 3.2lt Passat V6 Highline wagon, then two R36 wagon's. I use the paddle shifts 99% of the time and it works brilliantly. I have had the occassional hesitation when shifting from a high gear to a low gear after initially going up the gears and then deciding to downshift, but this is only on the odd occassion.
I like the DSG so much that I am loathe to go back to a normal manual gearbox or, God fobid, to a normal auto.
