G-8VXWWTRHPN Timing chain and tensioner discussion and issues - VWWatercooled Australia
  • #61
    Originally posted by Tuan View Post
    This is very useful guys, I have a 2012 VRS (2.0T) and as mentioned, 2012 was the year the offending parts got upgraded.
    Any specific month build, or just anything from 2012 onwards is OK ?
    Car is coming out of warranty soon and I don't hear any tappety tap tap from the chain (fingers crossed)!
    (Gonna do some Googling to see what I can add to this thread).
    You can remove your drivers side front wheel, loosen your inner wheel arch cover and then access an inspection hole (its about 5cm in diameter - covered with a plastic/rubber bung) in the timing chain cover to see which tensioner you have on your car.
    See here: http://www.vwwatercooled.com/forums/...ml#post1106088
    • #63
      The revised version of the tensioner has the ratcheted design - this is the fail safe that's been designed into the revised tensioner. Unfortunately none of the photos you have linked to show this clearly. If you look at my photos you can see the ratcheted design (almost looks like the thread of a bolt).
      The original tensioner did not have this ratcheted design - therefore if/when it failed, ALL tension was lost and the timing chain would skip. With the revised design, if the tensioner does fail, it will only retract a small amount and wont be enough for the timing chain to skip.
      Here is a link to a video which might help also: VWVortex.com - Timing Chain Tensioner replaced
      Also see here: How to Check 2.0T TSI Timing Chain Tensioner | Humble Mechanic
      • #64
        Too hardcore for me .. I can take a stereo out and door trims and dynamat the boot. That's the limit of my capabilities LOL ... I'll ask VW when they service my car (last service during warranty period) to check what I have.
        RS
        R
        • #65
          Must admit, I'm in the same (similar) boat.....I'm a driver as apposed to a mechanic.
          My 2010 GTI was a late 09 build, has 90+k on the clock and has shown no sign of wear or damage to the motor as yet?
          My clutch (6M) is even still original.....my nephew says I don't drive it hard enough, maybe this is why it is lasting so well?
          It is due for service again shortly, so will make some inquiries regarding timing and inlet issues.
          I would probably notice a huge difference I guess IF I were to just get these things done regardless....It's kinda like when you drive your car every day (only form of transport), you do NOT always see any small degradation to performance or driving status...It could be getting progressively worse each day? Who knows...
          Greg
          2015 Golf R
          • #66
            Unfortunately, when the tensioner goes ... the whole world blows up i.e. catastrophic engine failure.
            Seems that kms is not such a good indicator for failure either unfortunately .....
            The ticking form start up would be the best indicator, however, I don't think my ears are that good to be able to tell when the tensioner is going and the chain is slapping. These engines sound like diesels at the best of times !
            And well done on the clutch - you can drive a car hard and not be hard on the clutch - there is a difference. Explain that to your nephew
            RS
            R
            • #67
              As Tuan said, if the tensioner fails you will know about it because the engine will no longer operate. And if your inlet manifold was to fail, you would hear/feel the difference and you would have a warning appear on your dash asking you to take the car into a mechanic. Unless you are made of money, you wouldnt replace a working inlet manifold with a new one jsut for the sake of it. The tensioner however, might be a good idea because if this fails it will cost you thousands.
              As for the clutch, my GTI is on 81,000km with the stock clutch, and the past 20,000km have been at stage 2. No signs of slippage yet, although i don't abuse the car by doing burnouts and smacking gears etc....but it will start to slip at some stage simply due to the increase in torque over standard.
              • #68
                The tensioner in my 6 year old 95,000km 90TSI has rattled on and off for the past couple of years, but recently got bad enough to merit a trip to the dealer. VW Australia agreed to replace it under warranty subject to a reasonable (to me) part-payment because the car had been regularly serviced elsewhere. I was very pleasantly surprised at how easy it was to achieve that outcome.
                • #69
                  Tensioner / Timing chain Lawsuits in America
                  Many lawsuits are being filed against VW and Audi, over the tensioner issue on pre 2012 vehicles
                  I'll link a few below.
                  Volkswagen Timing Chain Tensioner Lawsuit Filed in New Jersey | CarComplaints.com
                  Volkswagen and Audi Timing Chain Tensioner Defect - Class Action Lawsuit | McCuneWright, LLP
                  Baron & Budd's class action lawsuit attorneys represent people hurt by defective auto parts and injuries from design flaws in car and truck components.
                  Volkswagen and Audi have been hit with another putative class action in New Jersey federal court accusing the German carmakers and their American subsidiaries of concealing information from consumers about a defect in certain models that "can result in catastrophic engine failure."
                  • #70
                    But that's America, where consumer law is different and you can sue someone for giving you a funny look.
                    • #71
                      I was hoping something similar may be happening in Australia, or if the lawsuit in America wins, VW / Audi are forced to do a re-call, and get everyone's fixed. and compensate previously grieved customers.
                      • #72
                        Will never happen.
                        • #73
                          haha.. i like that
                          TBH, here a lot of the Mk6 GTI's are likely to have been tuned. that alone would be used as a reason to defend the legal action from failing chain tensioners which are more prone for pre MY2011 GTI's.
                          MINI Cooper S Clubman - FWD
                          • #74
                            https://www.law360.com/articles/8032...ne-defect-suit
                            Do you have a problem with your timing chain?
                            • #75
                              I'm not very hands on with my car, but i recently purchased a 2010 mk6 golf gti with 90k on the dial, so that falls into the range of the cars that seem to have the weak timing chain tensions. But I'm hoping it doesn't have any issues..
