Forum only readable to users
The server is being hammered again by crawlers, we are seeing tens of thousands of "users" online. Rather than give up and take the whole thing offline, I've switched it over so users must be logged in to even read the forum. I've also removed the ads completely once you're logged in since they are now basically worthless and annoying.
It's not ideal, but it keeps things online for now until I work out a better approach.
Catatrophic Failure Oil Non Return Valve
  • Catatrophic Failure Oil Non Return Valve
    Hi guys I thought I would make a post after a pretty awful first experience of VW. A few months ago I purchased a 2010 golf GTI and straight away got the timing chain and tensioner changed by a mechanic to get that all out the way which went smooth and easy. After that I proceeded to get a interesting metallic hissing kind of noise which after a week of not much driving started throwing two error codes being P0011 and P0341 being camshaft and timing related. This ended up being due to a oil non return valve/check valve in the header of the engine. Part number - 06H 103 175. This part failed and started jamming shut at random intervals, this can determine how much damage is done as if the valve jams completely the top of your engine will be starved of oil. Pre purchase inspection did not find this issue prevalent so unfortunately seems like my luck happened within the few months of my ownership.
    This is a very rare and completely random issue but unfortunately due to its placement it is a very expensive fix to get the head off etc. Another issue is that if this issue occurs for too long you will get major engine damage which could go near $7000 in repairs. This part was also never updated so after getting it fixed there unfortunately is a chance it could happen again.
    So be careful TSI owners if you start hearing strange metallic hissing sounds be very careful and if anything like this starts occurring for you get the car into a shop ASAP for it to get tested, this is done by a pressure test through the cam bridge.
    If anyone has had this happen to them before please let me know because of how rare it is there is nearly no documentation on the issue.
    Not a good situation and costly at that, but I don't recall ever hearing a case of this item failing previously.
    14 EOS 2.0 TSI has arrived!
      Yeah I have been looking around and it seems like a very rare issue. I have found a couple of bulletins on the issue with the best write up being from a cylinder head company in Queensland. Ill link it here as it is an interesting read: Bulletin: VW & Audi Oil Non-Return Valve - Southside Cylinder Heads
