Hi guys,
I've recently purchased a manual MK6 118 TSI, and have been informed by a mechanic that the engine is losing compression in cylinder 2 causing a misfire. They've checked coils/spark plugs etc and the only solution they have suggested is to pull the engine apart and recondition it. It goes without saying that this would be costly, and I'm not sure that its worth paying for.
Is there anyone out there who could provide any suggestions/advice with regards to having this done? Or is anyone able to suggest where I might be able to purchase a replacement engine? I have the means to replace the engine myself, so the latter is probably preferred in this case.
Cheers!
Cheers!
