Not sure whether this should go in the Mk5 or Mk6 section... but I have a Mk5 GTI with a retrofitted Mk6 GTI steering wheel, adapted with a CH-version SWCM and using the original Mk5 clock spring. Until recently, it was working perfectly - steering wheel controls, steering assist, airbags etc. all functioning as intended - until the horn stopped working a few weeks ago.
I haven't done much investigating, but I can't hear a relay clicking when I depress the horn, so I'm assuming the issue isn't with the horn itself. VCDS scan doesn't show any error codes relating to the steering wheel or SWCM. I've taken off the airbag and fiddled with the connections for the horn on the back (all black wires), which hasn't fixed anything. From what I've read, it's usually a problem with the clock spring or the horn relay - I know the former is a bit of a pain to replace, and wondering if anyone has any other ideas? Or if anyone can help explain how the switch that activates the horn actually works? I got the steering wheel from a wrecked Mk6 and the wiring for the horn on the back of the airbag unit looks a bit janky, so wondering if that could be where the issue lies... any help appreciated
