Ok so I performed a compression test today on my MK5 Gti.
The test was performed on a hot engine, with throttle open and fuel pump fuse removed.
My results were 190-195psi across all cylinders. Wet test was 235-240psi across all cylinders.
Now I was thinking because of the increase of pressure on the wet test this could be piston rings, or will all wet tests increase in pressure?
Haven't had any issues with it other than it chewing up oil, but then that seems pretty common for the MK5 Gti. I'm also running a stage 2 remap if that makes any difference.
Cheers!!
Cheers!!
