I have an android DVD head unit fitted to my MKV GTI. All is well with the unit and I am now in the process of fitting the reverse camera. It, to is not OEM. The fitting instructions are a little bit light and don't seem to suit the wiring in the vehicle. I hope somebody here has already gone down this path and knows the tricks.
I have no problems, at this stage anyway as it appears straight forward, with the power pick ups for camera and light. It is the reverse trigger pick up that is the problem. The original fitting instructions were to cut the "orange wire" (in the loom that came with the head unit) if no rear camera was installed - I did so because at that time no camera was fitted.
The wiring loom that came with the camera, a separate purchase, has a trigger wire at both ends! My dilemma is - do I connect the trigger wire at the head unit to the "orange cable" that I previously cut (this goes to the canbus unit that came with head unit) after joining the cable again. I will try this and see if I pick up a power pulse at the other end if I dont get any hints from you guys. I know I can splice the camera end trigger wire to reverse light wire in behind the C pillar but I'm thinking this might not be required.
As you can see I'm a little at sea with this
, particularly after pulling the boot apart and removing the rear bumper today - had to fabricate a fishplate behind the number plate light opening to take the camera.
TIA. Eric.
, particularly after pulling the boot apart and removing the rear bumper today - had to fabricate a fishplate behind the number plate light opening to take the camera.TIA. Eric.
