QLD legislation:
Fog Lights:
• Fog lamps must be capable of being switched on and off
independently of any headlamps but must only be able to be
switched on when the parking lamps are on.
As I thought - illegal to have foggies that are able to be turned on without parkers. On my cars the front foggies switches do nothing unless parking lights or dip beam is on.
Driving Lights
• Additional driving lamps must only operate in conjunction with the
high beam circuit and must be fitted with an independent on/off
switch.
So driving lights should come on / off automatically with main (high) beam.
So, a car with ONLY auxiliary lights on (either fogs or driving lights) is illegal.
Note too that in the legislation the colour of the bulb (yellow / white) is irrelevant - if it's designed as a fog lamp, sold as a fog lamp, and wired as a fog lamp, it's illegal to use unless it's raining, snowing, duststorm, or otherwise reduced visibility (and no "night-time dark" does not count as reduced visibility LOL), The document above that applies to QLD states:
"except in fog or mist or under other atmospheric conditions which restrict visibility"
Fog Lights:
Driving Lights
switch.
