things that annoy me in my mk5
  • #61
    the only gauges i like are the newsouth ones. why should i sacrifice a vent for a gauge?
    one other thing thats annoying is the double locking of the doors.
    I'm selling my VR6
    • #62
      the OSIR gauge holder still has holes on it for airflow.
      don't know how good that is tho as i haven't play with one.
      mikinoz, where did you source your OSIR holder from and how much?
      thanks
      • #63
        OSIR still allows airflow. It is directed a good direction to so not to be annoying and in your face. As we have a smaller gauge air slips past the ring for the larger gauge also.
        It is the most OEM look pod I have seen. Reality is, they are cosmetic more than functional in the TDI but it is fun to have and see it ping 30 on short blasts.
        I bought my pod from Ian at Rennenhaus - let him know Mick sent you.
        • #64
          What double locking of doors? You press the button to lock the doors and they all lock.
          website: www.my-gti.com
          • #65
            im obviously biased but I think the VMR gauge is the neatest looking on the market. Its small and inoffensive. Its also cheap!
            It keeps my girlfriend entertained for hours!
            FOLLOW US ON FACEBOOK
            • #66
              you can disable the double unlock feature in the menu system
              • #67
                door locking
                If you mean the unlock driver's door/unlock other doors 'two step', that setting can be changed on the MFD (I think), just like the 'doors lock when speed exceeds 15kmh' (useful depending on your neighbourhood...). Pity VW won't let you change all the CPU mappings so easily...
                TG
                (formerly TSI GUY)
                First car: 1972 White Super Bug S
                First Golf: MY08 Candy White Golf GT Sport TSI DSG
                Now: MY13 Candy White Golf VI 2.0 TDI DSG (yes, I've come over to 'the dark side'...)
                • #68
                  Originally posted by VW Convert View Post
                  This thread is about what annoys you about your MkV, surely you aren't complaining because the cooling system is operating as designed even in the extreme heat?
                  Er . . no, but it would be reassuring to see the guage move ever so slightly to the warmer side on 40 degree days.
                  Originally posted by Maverick View Post
                  You don't have to worry about it, the car handles it all for you. If there's a problem the car will let you know.
                  You mean when one of the idiot lights light up? By that time it's too late!
                  Originally posted by Nardi330 View Post
                  plug and play, 3 in 1 gauge (boost + water & oil temp) and matching blue LED.
                  I like that!
                  • #69
                    TG
                    Not on my 32 you cant (Double door handle pull to open)
                    Ive searched as well as DrK
                    Must be missing something??
                    Can you post up a pic of what screen?
                    Bazzle
                    Prev 2008 R32 3 door DSG.
                    Now Lexus IS350 F Sport
                    • #70
                      That would mean your cooling system is stuffed!
                      No the temperature gauge will move before it warns you, it's not too late at that point but you should act when the warning occurs.
                      • #71
                        Bazzle
                        You're talking about something else.
                        The original question was about about double presses to lock which doesn't occur. I suspect that the question was supposed to be about the two presses to unlock all doors.
                        The two stage unlocking can be turned off and on via the MFD but earlier models without the MFD can have the dealer do this (or someone with VAGCOM/VCDS)
                        If you lock the doors either through the autolock or manually when you go to open the doors the first handle pull unlocks the door and the second opens the door. If you are using autolock the doors will unlock when you remove the key from the ignition or you can press the unlock button next the drivers handle.
                        Again you can set autolock in the MFD or via the dealer.
                        • #72
                          I'm pretty sure I read somewhere that the "clever" Vag engineers have put a software fiddle into the controller for the temperature gauge to make it always display right on 90C even when the actual coolant temperature is a few degrees above or below 90C. So the gauge does act a bit like an idiot light - nothing to see until it is outside the design temperature range.
                          Some nonsense about it being more "reassuring" to us customers or somesuch. IMHO it is more like the annoying deliberate inaccuracy designed into the speedo so it always reads a bit fast
                          • #73
                            In this case " reassuring" means "lying", plain and simple. The temp guage and speedo should really be set to indicate more accurately than they do.
                            • #74
                              ....when your mirror knob decides to fall off WTF ....
                              • #75
                                my knob fell off too!!!
                                (seriously)
