Jetta MK5 - Ignition Key issue
  • Jetta MK5 - Ignition Key issue
    Hi All,
    Ignition key refuses to go in? any ideas
    thanks
    Try some powdered graphite or lock lubricant spray from Bunnings or your hardware store of choice. Locks do need regular lubrication.
      Thanks for that, bought wd-40 which worked like a charm.
        Is worst stuff to use as it leaves a residue which attracts dust and will only block it up more. Either Graphite or Silicone spray is the stuff to use
          I hope OP was talking about the wd40 lock lubricant.
          WD40 make a bunch of stuff now.
          Sent from my SM-N960F using Tapatalk
            So do I as ordinary original WD 40 is not a lubricant, it is a penetrate for loosening stuck nuts and leaves a sticky residue so is unsuitable in this instance. But people have come to think it is a magic solution for everything. It isnt
            Its very name is a clue Its Water Dispersant formula version 40 and was developed to stop rust on Atlas rockets
            Times You Should Never Use WD-40 | Reader's Digest The bit about hinges is relevant to locks
