Jacking up your Mk V
  • #16
    Originally posted by WEDEL.1 View Post
    From the USA.
    Pure Motorsports, will take your credit card on their phone 866 397 5487.
    Stop Scratching Your Rear End and the rest of your chassis with our specially formulated soft plastic jack pads. PROTECH pads provide complete protection from the hard metal surface of your jack, preventing scratches, chips and dents forever when used properly. Stop using those blocks of wood, rags, and towels that can slip or tear through resulting in damage to your chassis. PROTECH&#039;S jack pads come in a variety of sizes and styles to fit almost any jack on the market today, from our simple over the jack head style to the side lift jack pads for lifting late model cars at the pinch weld. The jack pads are made of an extremely durable, patented material that&#039;s impervious to oil, grease and gas and will last a lifetime. As some of you may have noticed our protective pads have changed from yellow to black. We made this move to save on production costs and reduce lead times. The quality is still the same! The side lift jack pad makes lifting your late model cars easy. Simply place on your floor jack and lift at the pinch weld. No more hassle with the factory scissor jack. &lt;em&gt;Priced individually.&lt;/em&gt;
    From Adelaide the number was given as 0011/0018+1+213/323 then the ph no. 866 397 5487.
    No luck with that sequence. Right no. code was 0011+1+ their phone no.
    awesome, dont know what size you got do you??
    Blue Graphite MY08 3 Door GTI, Leather, DSG
    • #17
      No. I ordered part no 1007. Apparently the difference is the bottom of the pad.
      • #18
        The pads were waiting for me when I arrived back from Melbourne.
        • #19
          They fit easily onto my trolley jacks.
          Maris
          • #20
            Read the owner's manual.
            The jacking point's are on the sill panels & there are arrow's pressed into the sill panel to indicate this.
            The sill jacking point's are also much thicker too. Like 5mm thick! You won't do any damage at all.
            You don't need any fancy tool's or jacking pad's. It's strong enough.
            Where do you think the dealer's put the hoist arm's on all your car's?
            • #21
              Yes, I watched them at Solitaire this week, they have very thick Foam/Rubber blocks.
              Maris
              • #22
                I don't believe also that any mechanic who cares would use a trolley jack without rubber pad. Metal on metal is no good it will damage paint and deform metal at these jacking points. (Despite of tough paint on sill panel and stronger metal-the front of the golf is quite heavy).
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                • #23
                  I'm not sure about how cars stand up these days but when I was fixing cars, they still crushed at the jacking points if you weren't careful - Fords were particularly bad.
                  It doesn't hurt to take some precautions.
                  • #24
                    X2
                    I now use a rubber block cut from truck tyre with a groove in it
                    Bazzle
                    Prev 2008 R32 3 door DSG.
                    Now Lexus IS350 F Sport
                    • #25
                      Sorry guys
                      Haven't been here for a long time, Have been fighting Governments proposed mandatory internet censorship... Handing out flyer and son on..
                      For lifting my car I use trolley jack and 4x4 piece of treated pine left over from when i built me pergola
                      GOLF V 2.0 TDI COMFORTLINE
                      SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
