G-8VXWWTRHPN Removing FL drive shaft - VWWatercooled Australia
  • Removing FL drive shaft
    Hi all,
    I want to remove the FL drive shaft so I can put on a new CV joint.
    My Q is: as I'm rotating the drive shaft to get access to the gearbox end bolts, being a 4Motion, can the back wheels be left on the ground so it can rotate??? I'm unsure as never done the on a AWD before.
    Cheers for any advice
    Yes, it's fine.
    It's only 4Motion when the Haldex module says so.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      it is a 4Motion so i have to have all wheels off the ground I guess
        neutral
        MKV Sportsline Soot Belcher
        MKV Jetta FSI DSG
          No.
          With the key off, it is just a front wheel drive.
          '01 Beetle 2.0
