Originally posted by Fizz
View Post
MKIV Cluster Mods (Software Based)
The only really tricky bit is the airbag warning light is activated thru canbus on later cluster.
If you want a fully functioning FIS with the proper car emblem showing which door is open then you also need to swap over the CCM and window motors to the later ones as well.
If you get a Passat cluster you need to swap over the faceplate to the Golf version as they are a different shape.The later Passat with the chrome rings works too but you still need the Golf faceplate but the gauges will look funny as you will see the outline of the round Passat gauges printed on the foil thru the golfs gauge cutout section.PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
My cruise control light has never lit up; can this be corrected with VAGCOM or is one of these hex cracks required?
I'll add that to the wish list of DTE haha
MY03 GTI.'03 BMP MkIV Golf GTI | Oettinger tune | K04 | 18" OZ
'04 BMP MkIV R32 #144
search getnew
The light function is controlled by an engine ECU signal via canbus.
The function is programmed into the engine ECU chip.
Its not hardwired directly from the cruise control switch or anything like that.
Maybe the LED itself has blown in the cluster.
If not, then its not in the chip program.PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
Righto, my guess is it's program related as I'm sure I've read other posts where people have said their light never came on either. Might vary from MY to MY and the different clusters.'03 BMP MkIV Golf GTI | Oettinger tune | K04 | 18" OZ
search getnew
