Bit confused by some of the comments here?
Did the NZ R32's not come with cruise?
And why does the cruise light not light up when you activate your cruise control? is that something common with the GTIs and other Mk4 Golfs because I get a light on the dash when I enable my cruise control.
For me the only real useful feature is the enable distance to empty in the trip computer.
Same as mine. i already have the USB cable, i wonder if i can get the S/W somewhere else something to do when i get home
Nice find! Ill have to look into this i rection. I bought the auto window up/sunroof close on lock module from ebay a few months back. Cost me $40 with delivery. Its a use once only module and plugs straight into your Vagcom plug. Takes about a minute to complete. Best wank option ive ever bought!
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
hey Nashan, where off ebay did you get this? what did you search for? Im having trouble finding it. All got is a wiring kit for cars that dont have an auto option
To enable DTE I assume you use the cable and the software on a laptop to make the changes. Are the changes enabled via a menu or are there instructions on what values to program into the Prom, or do you need to know assembler? BTW, where is the port located to plug the USB cable into, under the dash?
Can someone tell me what MKIVs did and didn't come with the small red section at the bottom of the cluster? [The part with petrol/ambient temp etc] Mine's a 2000 GTI and doesn't have it - it'd be nice if it was just a dead globe but I don't have the buttons on the end of my wiper stalk to scroll through the options
Can someone tell me what MKIVs did and didn't come with the small red section at the bottom of the cluster? [The part with petrol/ambient temp etc] Mine's a 2000 GTi and doesn't have it - it'd be nice if it was just a dead globe but I don't have the buttons on the end of my wiper stalk to scroll through the options
Mate that means you dont have a trip computer.
They come out in 2001.5 Golfs.
MY18 VW Passat Alltrack Wolfsburg Edition + Panoramic Sunroof + some extra goodies... (Pure White) MY17 ŠKODA Superb 206TSI 4x4 + Sunroof + Tech Pack + Comfort Pack + some extra goodies... (Moon White)
Any further info on this?
Wouldnt mind switching on the DTE if possible.
Distance to empty is only available on Immobiliser3 clusters
ie
Glidns car had an imobiliser 2 cluster
1J0 902 821 A
so i got him a immobiliser 3 cluster which was
1J0 902 826 A
If the number in red is a 2 it means it has a half height display if the number in red is a 4 it means its is a full height display if it is a 0? or a 1 i think its no display
and the number 6 at the end means its immo3 if it was 1 or 5 it is immo2
make sense?
you need vag tacho to do the EEProm dump from the cluster
then you go to address $416 and replace the byte "C1" to "E1" save it and then re flash it
you can also do the needle light up mods etc
now i have changed mine so that the needles are always lit and then the cluster lights right up when the headlights are on
