ignition lock cylinder
This topic is closed.
  • ignition lock cylinder
    I wanted to replace the ignition lock cylinder and switch today. Found some good videos and here. I used the old screw driver and hammer trick but couldn't undo the shear head bolts. Any suggestions? Do I just need to bang harder and persist?
    Don’t give up, keep trying. You can use Dremel to cut the slot in the bolts.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      Exactly what we used to do. Cut a slot and if it was a screw type bolt we could then use a flathead screwdriver to undo it.
      2004 VW Bora 4motion | 3.2 Swapped - R32 Trimmings | BBS CH | Forever fixing this bitch
        That's what I did for my last one, cut slots then had a combo of hammer and screwdriver and trying to turn. I then replaced the shear bolts with standard ones for next time around. It was a little painful, but got there in the end.
          Use an air hammer
            Finally got there on the weekend with chisel & hammer! thanks for encouragement
