Another VR6 idle question
  • Another VR6 idle question
    Hey guys, Just after a few ideas regarding a 94 VR6 (so assuming obd1).
    The idle is rough when starting, jumping about which ive read is a normal thing, it jumps up as high as 1300 and drops super low, also frequently shutting off. This is mostly when starting, but regardless of warm or cold (although obviously more prominent in the mornings/when cold). So far Ive fixed a few things, and theres a few more to go, but would any of these have affected it?
    First, The breather box off the ISV was missing, but recently replaced that and cleaned out the ISV, which was pretty filthy.
    Then the fuse for "engine elektroniks" was blown, so replaced that, but it didn't seem to change much which I thought was strange
    The coolant hoses were replaced recently, but the hoses to the throttle body were not attatched, could this affect idle stability?
    The coolant is also quite low, would this affect the idle in any way? I noticed that once the thermostat opened it seemed to idle steadily on 850ish-rpm
    In short - what the **** can I do to fix my idle!
    Don't suggest a vag scanner unless you've got one that you want to use on this car
    Any help or suggestions much appreciated
    Look for vacuum leaks, trace the big black line from the brake booster around the engine bay, and the lines that branch off it.
    Look for cracks in the plastic joins, and for split or disconnected hoses.
      Thanks for the suggestion, I had checked most of them about 3 months ago, but that was before a major service at a mechanics, ill check again, thank you!
      Anyone else with suggestions keep them coming, I want to check everything off!
        Isv, tps, vac leak.
          1160
          1120
          1120
          1120
          1120
          1120
          1120
          1120
          1160
          1120
          1120
          960
          960
          960
          These are my engine revs from starting the engine until I started moving.
          After some distance my idle speeds while waiting at lights are 760-800 rpm.
          These values are data logged using a reader and my laptop.
          Hope this data can be of use to you in any way. I might add that I get engine code:
          00515 - Camshaft Position (Hall) Sensor (G40) 30-10 - Open or Short to B+ - Intermittent
          Not sure if that's serious but it seems I'm getting similar high idle as you.
          Past - '95 VW Golf MK3 VR6
            Hmm yeah that seems normal for idle, it seems to rev more and then calm down to a decent level. The TPS and ISV have recently been fixed so I'm assuming they are okay. I checked for vac leaks but couldn't find any. Is it possible the coolant temp sensor can play a part here? I've read a few places that it can affect idle :/
              Yeah, it's possible.
              A scan may reveal more with that, however.
                I really need to get mine scanned...
                Not only does it idle rough but the mileage per tank is crap with mine - only getting 350km's max per tank and it's all highway driving at 110
                .:R32
                8L S3
                Mk3 VR6 - SOLD
                Flickr
                  wow with that kind of consumption you may as well have a VR6 under the hood
                  Polo GTI
                  T-Roc R
                  Tiguan R
                  Tiguan 162 Allspace Wolfsburg
                    honestly not sure if youre being sarcastic or not >.> but yeah, it is a VR and when I do city driving I get roughly 250km's to a tank
                    .:R32
                    8L S3
                    Mk3 VR6 - SOLD
                    Flickr
                      lol my bad, for some reason I thought you owned a 4 banger
                      Polo GTI
                      T-Roc R
                      Tiguan R
                        Yea but if you wanted good fuel economy a vr swap isn't the right way to do it haha. Tomorrow I'll check the voltage to the coolant temp sensor and scan for codes
                          All good man
                          but c'mon, it should be "that" bad... Devs isn't even that bad!
                          Where are you getting codes scanned?
                          .:R32
                          8L S3
                          Mk3 VR6 - SOLD
                          Flickr
                            Doing it the good way and will just jump the plug. Dodgy obd1 spec
                              That is; If what I've read online is correct
