Dylan8's Vento
  • More mk3 hangs thanks to Dart
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    • Vento seems to have started a terrible idle. Starts off as a bit of a miss or vibration, after 10 seconds or so it turns into have a wild over sized cam.
      Feels ok once on the accelerator. Any way of testing the idle control valve without a vagcom?
      I unplugged the maf and it didn't seem to make any difference
      Bora gone
      Vento VR6
      MKIV GSW TDI
      7P Touareg TDI
      • Found the solution to the above. Missed a hole in the hose.
        New bushes in thanks to sneaky Pete, now to install the beam
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
        • Added the vr6 fire wall heat shield.
          What a night mare with motor in and brake lines plumbed in, hopefully keeps the floor and tunnel a touch cooler
          Fitted my oem coolant sensor cover finally
          Was going to fit my neuspeed strut brace, but it fowls on the coolant bottle, not sure if this is because I'm running a 2Lt one.
          Found and fitted a oem battery cover. Looks so much neater.
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
          • Good to read you are making progress.
            Really wish I had not thrown out my oem battery cover years ago.
            1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
            1996 Vento GL (white) - RIP
            • Cheers!
              Yeah I didn't even realise I had one until I stumbled across it at my parents house looking for other parts.
              Took the Vento out last night and so far so good. Floor and tunnel stayed pretty much cold, will see if that's still the case on a hot day when getting driven harder
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
                Cheers!
                I'm sure there's another culprit.
                My stripped mk3, no fire wall shield, rubber mat on inside removed as well as missing grommets in firewall was never 'hot'
                • Hmmmmmmm. I'll take it for a hoon on the weekend.
                  I found my other stock cat so might swap that over too and see if it makes any difference
                  Bora gone
                  Vento VR6
                  MKIV GSW TDI
                  7P Touareg TDI
                  • Exhaust manifold studs?
                    • Will suss those when i do the new exhaust manifold and down pipes
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                      • So no dice on the heat in the cabin problem.
                        The insulation cuts noise down, and held the heat at bay for longer but still managed to work it's way in this morning.
                        Next is suss the cat for a blockage and check for exhaust leaks in the bay/pre cat
                        Bora gone
                        Vento VR6
                        MKIV GSW TDI
                        7P Touareg TDI
                        • Sorted the rear suspension knock! Turns out it wasn't the rear beam bushes, although I will replace the beam soon anyway just so everything is fresh.
                          Oil and filter change, went for a lighter oil again this time.
                          Found one of the front engine mount/gear box bolts had backed itself out too and was sitting pretty loosely.
                          Car feels so much better and punchy now, I'm assuming the beam and loose engine bay bolts were causing a fair bit of movement and meaning the power didn't go straight to the ground on acceleration.
                          Picked up a welded and ported down pipe. Also a second set of exhaust manifolds so will have a crack at matching those too.
                          On to building a new set of wheels and start stage 1 of the exhaust in preparation for Vits hopefully
                          Iv put about 3200miles on it since the new cluster,
                          Fairly happy motoring other than running out of fuel a couple of times and the excessive heat and noises
                          Bora gone
                          Vento VR6
                          MKIV GSW TDI
                          7P Touareg TDI
                          • That's a heap of driving!
                            • Well done, good luck tracking down the cause of the excessive heat (I assume you have figured out what causes the excessive noise )
                              • Originally posted by HaydEn View Post
                                Was kind of suprised... hasn't really been driven more than 1.5hours away from home yet.
                                Cheers!
                                Few chassis plugs missing and bit of foam sealing the shifter to the tunnel are missing so let's plenty of road noise in.
                                Also an exhaust leak or two
                                Bora gone
                                Vento VR6
                                MKIV GSW TDI
                                7P Touareg TDI
