Dylan8's Vento
  • Unbolt slave cylinder from the gearbox and see if you get full travel with pedal.
    2000 Black V5 Bora
    1994 Charcoal VR6 Racecar
    • I know what the problem is. Feck. Must have had a complete mental blank on the weekend. The front bolt to hold down the linkages is too long and hits the slave...stops it from going to full extension. Same thing happened on Tim's 12v VR.
      xox
      • Originally posted by trickysimon View Post
        xox
        Will check both, but still think its something mechanical on the master cyl/pedal side rather then fluid given the fact the pedal cant be pulled up level with the brake pedal.
        either bent pedal,
        bent master cyl piston/rod.
        Think ill grab a second pedal to compare in shape and design, encase it has been swapped for one from another car or has actually been bent some how. if thats not the problem then think we can point the finger at the master cylinder in which case ill get a replacement
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
        • [IMG][/IMG]
          Anyone have the part number for the plastic retaining (number 5)?
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
          • From memory, if that clip is broken you need to get a new pedal.
            • I didn't notice it included with the pedals and ecs, and most places suggest it should be replaced whenever removed.
              Ill have to have another look
              Bora gone
              Vento VR6
              MKIV GSW TDI
              7P Touareg TDI
              • Not sure if this occurred to anyone before but, why not print that part using a 3D printer? You'd probably need some stiff type plastic but it doesn't sound impossible.
                And if we can somehow catalogue the blueprints for numerous small plastic parts that we need, we could just print them as needed, useful if the part is hard to find or nobody makes it anymore.
                Past - '95 VW Golf MK3 VR6
                • Originally posted by stefcio007 View Post
                  Probably a good idea.
                  Need a good example to start off with though to trace into a program like Cad or solid works
                  Bora gone
                  Vento VR6
                  MKIV GSW TDI
                  7P Touareg TDI
                  • I know someone with a small 3D printer
                    • Just noticed my battery and terminals seem to be around the wrong way.
                      positive is at the front/engine corner, negative is at rear/engine corner.
                      Lots of other VRs online are positive at rear/coolant bottle corner, negative at front/washer corner.
                      Anyone comment on this? need to order a new battery asap.
                      Thinking this battery if it makes any difference. Terminals are in the correct position for my current setup
                      Bora gone
                      Vento VR6
                      MKIV GSW TDI
                      7P Touareg TDI
                      • Mine is negative at rear.
                        • Originally posted by HaydEn View Post
                          Cool.
                          They on the motor or washer bottle side of the battery?.
                          Bora gone
                          Vento VR6
                          MKIV GSW TDI
                          7P Touareg TDI
                            Cool.
                            Motor side.
                            In theory battery orientation can be whatever your wiring allows. Assuming you are away from the car and going off memory?
                            • I just find it wired they are different. That's how the wiring was in the golf, but it was a bit of a battle to tuck it under the tray etc, and does seem a touch short on the wires.
                              Ordered a battery to suit, at worst if it's too long I'll spin the battery 180 deg to matxh everyone else and ill just have excess wiring
                              Bora gone
                              Vento VR6
                              MKIV GSW TDI
                              7P Touareg TDI
                              • I looked at the picture a few pages back. Mine sounds the same as yours.
                                Bora gone
                                Vento VR6
                                MKIV GSW TDI
                                7P Touareg TDI
