Hello,
What do you guys think is my problem? engine is 1.6 8V EG Motor
At cold start up no smoke
Once the car comes up to temp regardless of idling, acceleration, cruising the car blows smoke. The smoke is oil burning and quite a bit of it.
The car has been sat for around 3 years without turning a wheel so first I thought stem valve seals when engine warms up the vacuum from the piston draws the oil in past the valves. Whipped the head off, stem valve seals appear ok but i will change anyway. Valve guides have been changed.
There is no apparent signs of head gasket failure.
What I have noticed is quite a lot of oil in the intake manifold...I don't think is is normal?
The pipe for the PCV valve is worn and cracked but not split and the PCV valve it self doesn't appear broken, but once again a bit of oil here.
So while the engine is in bits what else should I check/replace?
Any pointers and help is well received.
Neil
Neil
