78 2-Door Build Thread
  • Looking good.
    Golf GTI 1980
    Golf GLS 1979
    • Who did the Reco, dude? Spot on job.
      • Bloody hell! First time I've seen a smooth un-cracked, un-faded MK1 dash!
        Congratulations on that!
        • a guy out at eastern creek in NSW. did a very tidy job and was very affordable. if your in a rush however, probably not the guy to go to...took approx 10 weeks.
          • got the new head on today, cleaned it all up and put all the pieces from the vrs kit in.
            just waiting to fix up a few things here and there but otherwise, should have the motor in next weekend if all goes well...
            paited some more bits and pieces...will put photos up tomorroww
            going on a drive now with dom123 and myself (2 red mk1's) lol
            • Motor should go very nicely with that top-end! I'm jealous.
              • wow that dash looks grouse!
                well worth the wait!
                and woot for cruising in the mk 1's!
                • 78 2-door 1.8 KR 16v - twin dellorto's
                  • so the top end is all done, still have to tidy up the bottom end...i want to give the block a clean and a paint as best i can...also considering getting a new water pump as it looks pretty well used?...
                    one of the threads in the gearbox holes is shot and the bolt doesn't bite so i will have to get it re-threaded...
                    • Nice engine
                      What adjustable timing gear you got there? Looks just like ours.
                      Golf GTI 1980
                      Golf GLS 1979
                      • Simple goodness.
                        • looks good mate! keep it going.
                          is that one of the old school techtonics tuning adjustable cam gears?
                          how are you going to run the ignition advance?
                          87' MK2 GTI
                          13' MK7 TDI
                          • That's what this forum need, More carbys!
                            Lookin' good!
                            Pages 28 and 29 of my wreck to race thread show how I made up a throttle cable which might be of assistance to you.
                            Pete
                            7? MK1 Caddy
                            79 B1 Passat Dasher Project
                            12 Amarok
                            • bought new water pump today, thought it would be a simple swap...but the internal diameter of the original pulley wheel is much larger than the fitting on the new pump so the wheel/pully doesn't line up with the holes, nor do the bolts/washers...anybody got any ideas?
                              i will probably ring vw tomorrow and see if i get a later model one and see if it's any different....
                              • Sounds like you got a late model pump. I think (but you'll need to check) that a MK2 pulley might be what's required.
                                7? MK1 Caddy
                                12 Amarok
