So it now sounds epic?
Team Green 16V
love it when you get a phone call like
"yo mik, this back box is way to big, do you feel attached to your spare wheel well"
"no not really"
"cause im gonna take to it with the grinder"
commitment or madness you decide, i think a little of each.
all jokes aside the set up really worked well, no drone at idle and low revs and then screaming rally spec splatter up the rev range.
loved as mik test drove it for the first time and was hitting it towards the dead end in the soaking wet, i watched in fear as he topped out 3rd with just enough time to get on the achors and slide towards a locked gate of the nearby factory/estate. looked hairy from where i was standing.
sounds great
although not much of a fan of the floor modifications.
Great job Al, When you going to open your own VW Fab shop?VW: it aint just a car, its a way of life
Just read through this entire thread, kudo's for sticking with Digifant!
The engine just sounds better and better the more load you put on it. It sounds like its asking to be thrashed!
Awesome car and engine combo
HAHAHA
I wish, am doing more and more stuff. And obviously enjoy it. Bring on the next projects I say, I'm up to anything.Oh and on a side note a 2 1/2" system on a mk1 is a major squeeze , and a super challenge getting it over the trailing arm. Clearance was/is down to 5mm ish at spots, having said this the hole system doesn't knock at all, bar the tail pipe which we are going to sort with some panel work , and closing up of the gaping hole from the twin abortion.Originally posted by GoLfMan View Post
Fiddled with hangers, mounts and rear panel so I've no knocking now.
There is an exhaust leak in the bay from the joint where the 2 sections of header connect so I'll arrange to take that off and get it welded to replace the sleeve.
Took some MKV GTI owners for a spin on Thursday night, they quite enjoyed it.
It sounds phenomenal Mick. Thanks for the ride! Hauls a$$ too.
Deep at idle and wonderfully raspy as it goes up through the gears. I was surprised how non obtrusive it was when sitting in the cabin. It's there, but it doesn't drone at all! It sounds like a race car, but like we were saying, more condensed, or compressed. Same character though. 100% goodness. You've got to be happy with that.
Time for another dyno run me thinks.
well, Ill put my hand up as your first employee. Im pretty handy with a TIGOriginally posted by alex g View PostI wish, am doing more and more stuff. And obviously enjoy it. Bring on the next projects I say, I'm up to anything.Oh and on a side note a 2 1/2" system on a mk1 is a major squeeze , and a super challenge getting it over the trailing arm. Clearance was/is down to 5mm ish at spots, having said this the hole system doesn't knock at all, bar the tail pipe which we are going to sort with some panel work , and closing up of the gaping hole from the twin abortion.
also not all that bad on a lathe and mill ahah
I was off to visit Brenton earlier today to get some bits, filled up the car near home and 5 minutes down the road the car starts playing up. Massive miss in every gear all though the rev range. I nursed it home and cleaned the plugs but to no avail, still was not happy. Starting with the basics I pulled the plugs out afain to confirm they were sooty and proceeded to check spark.
Luckily I started at the coil. I removed it pulled the terminals off and brushed them to remove some corrosion and she is running bang on again! Very satisfying but digit is so tempremental to current fluctuations and earths it is not funny... Probably runs better than before!
