Originally posted by manol
View Post
Campaign 23H9 - 103kW/125kw TDI PD Piezo Siemens Injector Failure
should be a easy fix.. either issue with loom and vas pc will pick on which injector or they have not seated injector correctly... i saw one that was missing like crazy but it cleared after a good road test...VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Originally posted by sn809 View PostCheers for that, got in touch with Vw Australia and my car is eligible as well. Now who to go to is the question.Originally posted by manol View PostAny dealer? Who cares, they'll all do the same work.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Yep Ipswich or Highway would be my immediate Brisbane choices.
Approximately late 2008 VW "started" using double o-ring injectors "in some cars", as far as I can work out from the piddly amount of information VW release about this problem around the globe. You can have a 2008 model that will be fine, or you can have a 2009 model which is affected. If it is early 2008 like mine, that is build date, well you're in the firing line.
This could all be totally wrong, VW won't confirm or deny anything.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Originally posted by Greg Roles View PostYep Ipswich or Highway would be my immediate Brisbane choices.
This could all be totally wrong, VW won't confirm or deny anything.Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
Originally posted by stormshark View PostNor will they pay for the cost of a towtruck for those in cars that fail before you can get them in for the recall.Glad that they have come clean now for those that haven't had this happen to them(injector fail), but the occurance and Lack of tow truck expense contribution, still leaves a sour taste in my mouth!
To be honest if I was not a member of this forum, I would not be aware the car has this problem and that a fix has been issued by the company.
Originally posted by JimmyT View PostSo the new injectors have fixed the issue?2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
I figure so, as the single o-ring injectors fail as oil eventually gets past the single seal, two will just last longer in my opinion. Probably dramatically so to be honest, as I am sure it's been redesigned to seal better as well. I expect the new injectors to outlive usual engine life though, but we shall see.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Re: Campaign 23H9 - 103kW/125kw TDI PD Piezo Siemens Injector Failure
Originally posted by Greg Roles View PostI figure so, as the single o-ring injectors fail as oil eventually gets past the single seal, two will just last longer in my opinion. Probably dramatically so to be honest, as I am sure it's been redesigned to seal better as well. I expect the new injectors to outlive usual engine life though, but we shall see.
Sent from my GT-N8000Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
More info on the campaign here
Injector Failures - Possible recall - Page 53
Technical background
On some vehicles with the 2.0l TDI engine, deposits can settle on the Piezo pump injector elements because of dirty engine oil. This can lead to running problems. Not all vehicles are affected by this campaign! On the affected vehicles the Piezo pump injector elements must be checked and if necessary replaced. Please make sure that on the affected vehicle the check and repair of all open campaigns/measures are performed during the workshop visit.
Parts to be fitted as part of this campaign.
1x Campaign 23H9 sticker 000 010 006
1x Wiring loom adapter 03G 971 033 M
4x Adjustment screw WHT 000 530
5x M8x58 socket head bolt N 105 811 01
8x M6x88 socket head bolt 03G 103 385 A
4x Pump injectors
Seems a bit weird that VW would replace injectors fouled by dirty engine oil without fixing the engine oil problem at the same... or has something else changed too like oil specification??2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
