OK, so now I am saving myself pain I hope. The above-mentioned brake master cylinders are causing problems. The garage mechanic had me send back the correct one because it has four ports. When i contacted Tooley Imports I was sent a two-port one. This it turns out is totally wrong in length and location of the brake line ports.
Tooley now says that the first one was the correct M/C for the TDI. It just needs a couple of grub screws to blank off the unneeded ports which they supply at $14 each. The mechanic says he wont do that as blanking off is unsafe and prone to failure, and suggests I go for a re-sleeve of the original.
Cost is ball-park the same.
Any views would be much appreciated.- I feel a bit caught as I have read a re-sleeve may not last as long as a replacement.
Yowie
Yowie
