Well it looks like my descripts might be well off for a Mk3 Golf... just a blade and spring!
The polo 6N stuff is very different, even the newer 9N polo we have has similar crappy parts that will break like the 6N
So I don't really know which part of the lock you have broken from the pics for a Mk3 Key bits.
\( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
Yes, finally got around to buying in parts and pulling the handle, after buying vaseline and new pliers just in case.
Turns out it is a simple paddle with a hook and spring.
I this case the hook broke off.
Luckily it left a bit of hook in the hole so the spring stayed in place which is why the key was returning to vertical all the time.
That has also meant the spring stayed on the lock instead of falling inside the bottom of the door.
Not so luckily, the hook I ordered is too big to go in the hole/ring bit on the end of the barrel.
I was careful to tell the parts ppl which year model I had as there are two hook and loop sizes.
It would be good to know which is which in terms of models.
So, whether I have a replacement lock already and need the younger hook, or a later model hook.
Monday will tell.
Once I have the right size hook, should be a pretty simple fix. I am not looking forward to replacing an entire barrel, that looks like more hours than I can concentrate
MY09 Golf Candy White 2.0 TDI Pacific
MY95 Golf III TDI
Good news.
Got my hands on a Tooleys lock kit and replaced the whole thing.
I was very hesitant when I saw the barrel and the seven little keys and matching teeny springs.
Worked a charm once I found a prising tool to get the seven tiny key springs out of the lock.
And petroleum jelly is great for lubing and keeping it all together while you go.
The kit included the bigger new hook, so all good. I will get another for the passenger door.
If following Youtube man, watch for the fudge while fitting the last bigger spring to the hook, that is the spring that holds the hook and paddle out straight. I struggled for ages trying to assemble it as he suggested.
Then I noticed the spring has ground ends and was able to thread it around the hook after I had inserted the hook into the loop.
The Youtube clip shows the hook being inserted with the spring already in place.
But he also cuts the video so you don't see how they actually go together
MY95 Golf III TDI
Hello VW Watercooled, So another six months and all good, until today.
Wouldnt start in the cold. Battery is new-ish.
Sometimes the after-market turbo-timer acts up and needs neutralising. (Process is to turn the motor off, hit the turbo timer zero switch, and start up.)
Low oil, really low, after a country trip. Go buy Penrite Enviro+ ,505. 504-507, 5W-30 ($82 Supercheap, not,) in case that is the reason.
No dice.
So, I chickened-out and called the roadside assist mechanics (RACQ). They isolated the turbo-timer, but that made no difference.
The engine starts and runs about 3 seconds and then cuts out.
This is the same way the turbo-timer plays up.
So unless a brainwave intervenes, we are getting it towed to local garage.
Any suggestions would be very welcome.
Cheers, Yowie
MY95 Golf III TDI
Immobilizer would fit, thanks Gigitt. I guess we will see.
I dont have access to VCDS and assume they/it wont be cheap- I dont have the laptop either .
I guess thats what garages are for.
MY95 Golf III TDI
Gigitt, thanks for the suggestion.
It was the chip in the key.
Car started first go when I tried it with the spare key which is the factory one.
Back to the random local key cutter to see what, if anything, he has to say.
MY95 Golf III TDI
In the interests of keeping my silly questions in the one place...
Yesterday I was using the Mk 3 to launch a boat. Diesel pulled it easily on the 8-1 ramp. However at the time there were people standing between car and trailer and I couldnt move it, a wake wave came by and submerged the rear axle.
I hosed underneath as its a salt river, and noticed the S/S muffler for the first time.
Question is, do I need to pull the rear wheel bearings or are they sealed well enough?
I have read the manual and they look closed in but any more intelligent views are very welcome.
Is there anything else needs servicing as a result, aside from my brain?
Thanks in advance.
MY95 Golf III TDI
Salt = rust, no matter how well you wash.
(And Sand)
At least the bumper is plastic so it will hide anything that might rust.
Rear bearings are not water tight - nothing is really. Rear bearing are races on spindle that is attached to rear beam.
You should have spotted a bloke with a 4x4 a fiver ($) to launch the boat for you. and another fiver to pull it out.
Yeah tow it by all means, but get someone else to put their car/4x4 into the water.
One thing to wash thoroughly is the aluminium brake weight propertioning valve on LHS of car attached to the rear torsion beam.
All the rear brake lines attach to this and there is a metal plate with a spring and rubber boot covered piston.
Thanks, Yes, I thought the same. Its a school thing, might get a parent with 4x4 next time.
It wasnt a tow, just a club boat needing a 30m launch.
I will get the bearings done and wash that valve and spray fish oil.
Including up behind and under the bumper.
I pulled the spare wheel and that looks fine in there.
MY95 Golf III TDI
So the car failed to stop yesterday after fifteen minute drive, the last at 90kph.
I wasn't driving, but apparently the pedal went floorwards on the off ramp. Luckily they found a gap and could use the handbrake. I came by an hour later. No fluid anywhere, level good for brakes. Rear wheels reported as hotter than usual. Drove home no worries.
I am now wondering if I didn't clean the brake proportioning valve properly after its dunking... taking it to the shop.
MY95 Golf III TDI
could be leaking seals in the master cylinder, or even something like warped disks causing the pistons to retract a long way into the cylinders (taking a couple of pumps to come out properly??)
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Pulling the rear wheels and brakes, there are grooves matching the pads suggesting the rear drums are well-worn, but otherwise it all looks OK. No pedal or wheel vibration on braking to suggest disc warp.
The P-plater was driving, so could have been anything, he's averse to using the engine to slow down and may or may not have left the handbrake slightly on, and there were four large adults on board.
Thanks for the thought, appreciate it. Will let you know what I get
MY95 Golf III TDI
I am recording this to save others' pain.
Seems the brake master cylinder is on its way out in the MK3III TDI.
And that there are two sorts fitted to at least the TDI, with either 2 or 4 inlets holes, and different bore sizes, 20 or 22mm.
You are in luck if yours is the four port brake master cylinder as they are more common and around 40% of the cost of the two port ones.
Tooleys had both, most places have only the cheaper 4 port one.
Happy motoring
MY95 Golf III TDI
