Making healthy power - have you fitted a HPFP such as the Autotech unit yet? If not, then theres more mid range to be had.
Tigger73's Scirocco R
Tigger73's Scirocco
No HPFP or intercooler so the power output is fuelling limited at the moment.Originally posted by Lucas_R View PostMaking healthy power - have you fitted a HPFP such as the Autotech unit yet? If not, then theres more mid range to be had.
If I did these 2 mods I'd be pushing 235kwaw and the only thing stopping it going 12's on the 1/4 mile would be lack of traction.
I've actually driven a stage 2+ Scirocco with semi-slicks and 235kwaw and the thing is brutally quick, but still struggles to get the power to the ground in 1st, 2nd and 3rd gears. The issue then becomes intervention of stability control in 4th gear causing throttle cut due to wheel spin.Last edited by tigger73; 12-08-2017, 12:03 AM.
Doing a thing today...
Calipers painted. Happy with the way it's come out.
I'll check but I think it was just a piece of gravel/rock.Originally posted by iampivot View PostIs that a screw sitting in your tyre?
Got the same power out of my R but with the torque hitting around 433nm. No HPFP or IC although the IC is getting installed next Thursday.Originally posted by tigger73 View PostRan the car on the dyno today - 222kwaw...
Is it an IS38 turbo in the Rock?Current:
2023 Mk2 Tiguan R - Lapiz Blue
2015 Mk7 Golf R Wolfsburg - Limestone Grey: Stage 2
Gone but not forgotten: 2008 Polo GTI Shadow Blue
Scirocco has the same engine as Mk6 R with the K04 turbo.Originally posted by Servo View PostGot the same power out of my R but with the torque hitting around 433nm. No HPFP or IC although the IC is getting installed next Thursday.
Put my RamAir intake on this week. Man it is loud! My wife isn't a fan (but I don't particularly care) haha.Originally posted by tigger73 View PostInstalled a Ramair CAI.
Did you have to modify (trim) the aluminium heat shield plate to fit around the headlight and radiator pipe?
Yes it is loud and my wife is not a fan either (she feels a bit self-conscious when driving and thinks everyone is looking at her).Originally posted by Tobes_WIR35 View PostPut my RamAir intake on this week. Man it is loud! My wife isn't a fan (but I don't particularly care) haha.
No modification necessary. I had some clearance concerns with the fan, however when the 2 parts of the cover bolted up it pulled the bottom section away.
I'd already installed a Forge DV so haven't run it with the stock DV.Originally posted by Tobes_WIR35 View PostDo you know whether it's possibly to tighten the diverter valve spring so it doesn't discharge at such low boost levels? I'd prefer to hear a bit of flutter rather than the long pssshhhtt noise...
OK after further consideration I've decided to go back to stage 1. Boss at work had made some comments and wife wasn't happy with the noise. I'm not really concerned eitehr way but I understand the boss' point of view (it's a company paid for vehicle).
Anyway my loss is your gain. Exhaust and intake have been removed and are for sale:
Ramair Intake (Audi/VW 2.0 TFSI K03/04) - $180
Scirocco R 3" stainless turbo-back valved exhaust + wifi switch kit - $2950
Went past the grain silos at Coonalpyn today and took a compulsory photo...
