:: ECS Tuning :: VW MKIV 2.0L AEG Valve Cover Gasket Kit - Click Here !!!
  • :: ECS Tuning :: VW MKIV 2.0L AEG Valve Cover Gasket Kit - Click Here !!!
    VW MKIV Golf 2.0L AEG Valve Cover Gasket Kit - Only $139.95!
    Whenever a service is performed that requires the removal of the valve cover, replacing the gasket is so simple and effective that it should be done every time.
    A common source of oil leaks and excessive engine smoke, the valve cover gasket seals the engine cover to the cylinder head, allowing oil to effectively lubricate your valvetrain.
    The ECS assembled Valve Cover Gasket Kit is a complete valve cover servicing, alleviating concerns of future problems by addressing most of the components above your valve cover as well as the gasket itself.
    http://www.ecstuning.com
