Hi All
I know this topic has been covered many many many times, butno matter how many posts I read I still can’t find the solution to my issue..
So I installed a “low line” camera to my 2013 GolfComfortline but I cannot get it to show anything on the screen. When I put thecar in reverse the radio unit does all the right things and changes to the reversecamera screen, but nothing shows up.
Things I’ve tried so far:
- Going over all the wiring and installation notesand can’t find anything wrong
- I read some posts about the reverse signal beingpulsed by the BCM so I’ve put a replay on the camera as suggested
- Reversed all my steps in VCDS and started fromscratch
- I contacted the seller from Ebay who I got thereverse camera from and they said it’s probably because my unit is a RNS-MID,not a RNS-510. They said the camera will also work with the RNS-MID unit butthey don’t know how to modify the programming
I guess it has something to do with programming as I get 2faults when I do a scan. 1 is the “37-Navigation -- Status: Malfunction 0010” andthe other is “56-Radio -- Status: Malfunction 0010”. It keeps complaining thatthere is a fault in the “Control Module for Back-Up Camera”, which doesn’t makesense as I installed a low line camera (without backup module). I have been tothe module installation list but that module is not ticked..
Below I’ll post a pic of the camera I purchased from Ebay, a pic of the screen when the car is in reverse, VCDS screen shots and a dump from VCDS.
