I started flashing my CAN gateway, ignoring the message "Warning ! Flash file is incompatible with ECU Number. Do you want to continue ?". That message was not that confident at first time !
The flashing process took about 20~30min, and I have connected a battery charger for the car and computer was also connected to a charger.
I finally got BL firmware flashed successfully.
However, I had to recode Battery Regul. as coding has been lost for some reason.
For people who need to upgrade can gateway I do recommand to make a full scan using VCDS and save the results.
This will be very useful to compare coding values before and after can gateway firmware upgrade, and fix codings if necessary.
Thanks.
Thanks.
