Does 5K0 919 475 E sound right?
Discover Media retrofit
Hello,
I'm new in here and want to share my experiences. I have a Tiguan 5N 2014 with factory fitted Dynaudio and rear OPS. I upgraded to RNS 510 and RVC (highline) about some months ago.
So I fitted Discover Media (Index G) 2 days ago. Everything works as expected (even with older gateway without 5F support), except my Highline RVC (it's just disconnected for now). I nearly read all pages in this thread and I am going to fit newer 7N0...B RVC module + new harness from back to front. I will get a completely new 7N0 module, i hope i can get it calibrated without ODIS?!
In addition: Right now I have the camera 5N0827566AB installed, will it still work with the new RVC module? Some say yes, some say no (..... AL camera is mentioned instead).
I will also fit a new PDC module to make the PDC display work together with the RVC camera (but will do that later).
I managed to configure the Dynaudio amplifier in adaptions + coding, but my feeling is that the sound was way better with the old RNS 510.. anyone else has the same experience?
Greetings to all dm retrofitters
VW Tiguan 5N - 2014 - and still happy :o)
Welkom! I noticed a slight difference but think it still sounds better than most other cars out there.Originally posted by Deezah View PostI managed to configure the Dynaudio amplifier in adaptions + coding, but my feeling is that the sound was way better with the old RNS 510.. anyone else has the same experience?MY12 Golf R | 5 Dr | Deep Black | DSG | Discover Media retrofit | RVC retrofit | DYNAUDIO
You need ODIS S to run RVC calibration routine, as well as the calibration board. It will not complete with the older revision of camera.Originally posted by Deezah View PostHello,
Much easier is to just use an aftermarket camera that doesn't require calibration.
What exactly are your coding/adaptation settings for amplifier?2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
You'll need to replace it with a 1K8 module (which also needs an adapter harness, or you can repin all the wires)Originally posted by aswigon View PostDoes 5K0 919 475 E sound right?
Golf VI assembly 1K8 919 475 E2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks for the info. I will have to go hunting for some information on where it is physically located as what I have found so far left me confused.Originally posted by kamold View PostYou'll need to replace it with a 1K8 module (which also needs an adapter harness, or you can repin all the wires)
Golf VI assembly 1K8 919 475 EMY12 Golf R | 5 Dr | Deep Black | DSG | Discover Media retrofit | RVC retrofit | DYNAUDIO
It's up above the driver's footwell, above the relay carriers. It's a fair way up there behind the dash.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Hello kamold,Originally posted by kamold View PostYou need ODIS S to run RVC calibration routine, as well as the calibration board. It will not complete with the older revision of camera.
regarding Dynaudio here's my setup:
Byte 4-7 - AA000000 2 Channels / 4 Passive Speakers installed (PR-8RH) or Sound system (PR-9VE)
Byte 11 - 03 External Sound System installed (PR-9VE)
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D => activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus => Databus Infotainment
MAS00950-Audio Parameter => 0
ENG117919-Startup_Screen_Sticker_HMI => 00 02
On my car's sticker there is "PR-9VE" noted (I ordered Dynaudio from factory). My amp is 5K0 035 456 C / KonzernAmp 8K H07 0202. I'm missing the sound "dynamics" a bit. The RNS 510 was way better regarding the sound.
In your entry post you wrote:
"Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)"
Do I need to change byte 11 to 05 maybe? VCDS is missing that label though, only 01 and 03 is shown, but ofcourse one can enter it manually. With my current setup: balance/fader is shown correctly and it works as expected.
And does anyone have experience with a converter for the original highline RVC? I'm thinking about trying one out.VW Tiguan 5N - 2014 - and still happy :o)
I already wrote a reply, but it needs to be confirmed by a moderator?
Ok, i edited this post for now:
Hello kamold,
And does anyone have experience with a converter for the original highline RVC? I'm thinking about trying one out (although I already ordered the the RVC module + RVC camera + harness).
Last edited by Deezah; 18-09-2019, 06:31 AM.VW Tiguan 5N - 2014 - and still happy :o)
Byte 4-7 should be 000000 as you have 8 passive speakers, not 4.
Byte 11 is correct for Golf Dynaudio 250w amp (03). It's 05 for Passat Dynaudio which is a different 600 amp.
VCDS label file is not complete.
You can't use a converter with highline OEM RVC. It doesn't work.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Yes that's correct it's 250w, same as the VW Sound System amplifier.2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Ok, i changed the setting but the audio is still worse (I really don't like it right now). I still need to test a little bit.
Regarding RVC: I am going to install 7N0907441B RVC module. Do I still need to get 5N0827566AL camera (right now I have "AB")? I read that only index "AL" allows a correct calibration.
Is there another chance to get a correct param for Tiguan without ODIS online? With access to a Tiguan with factory fitted Discover Media + RVC, might it be possible to dump the params (VCP?) and load it on my module?What is required is parametization from a Tiguan which is only available with ODIS online. Then calibration data must be loaded to the module either via directly dumping the EEPROM contents or running the calibration procedure in ODIS.
It's just an idea.
You can directly write the eeprom with a suitable eeprom tool. You can't do it with VCP.
Yes you need an AL camera for the calibration routine to complete successfully with ODIS S.
As for the audio it sounds like something is not setup correctly. Should be on par with the RNS5102011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|9w7 BT|THA475 Amp+active sub|Whiteline ALK|RVC|
Thanks for the info. I will install the new RVC package in the upcoming weeks, when I have time
I will then look at the setup/calibration (too bad there is no chance with VCP). A friend of mine has the old highline RVC indeed working with a converter on DM. But the quality is not that good - sometimes he has horizontal lines running through the picture. That is no option for me.
Tomorrow I will check the coding regarding dynaudio again and post back, maybe some adaption channel changed back after some coding.VW Tiguan 5N - 2014 - and still happy :o)
