2024 maps for Discover Pro MIB2 (P353)
Map updates - Discover Pro
Looks like VW have finally fixed the site. I reached out to VW Aus last week and laid the problem out for them in detail with screenshots, URL's etc - got a cookie-cutter useless response. But coincidentally a couple of days after I reached out to them, the issue resolved and the update files became available.
Not sure why VW globally are so tardy with making the update files available through their portal when other brands in the family manage to push them out, but oh well - it is what it is.
Anyway, thought that anyone who was waiting would like to know.Cheers
Yeah got it a few hours ago Just need to go for a drive in the Kamiq now Has 22.12 so will see what it changes to.
Bloody Skoda are away behind Hasnt been one on there for months
Had to have car idling this morning as got a snake up under rear . While it was doing that the maps updated from 22.12 to 23.6 so it does work the way I do it. Snake crawled out as muffler got too hot for it I think Was only a green tree snake.Last edited by Guest001; 09-02-2024, 09:36 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
[I just updated our first gen 2017 162 tsi tiguan. Just unzipped the 25gb file to a micro sd with adapter, put in car, went to version in maps and clicked update.
Went through no issues. Doesn't really feel any different and I went from 2017 to 2024 in one jump. I'll use it tomorrow and see if there is anything different2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
Originally posted by REXman View PostWent through no issues. Doesn't really feel any different and I went from 2017 to 2024 in one jump. I'll use it tomorrow and see if there is anything different
I'm getting some sort of error with this update. I've updated my maps several times before without issue.
The screen shows that I now have the current version but my maps cannot zoom in closer than 40km.
The "version back documention screen" has no option to accept the error code, other than the cancel button.
If I enter an address to navigate to, the voice commands work ane a zoomed out (40km) summary of the route will show, but it's like no close up detail can be showed now
I thought that the file downloaded was corrupted, and so I downloaded it again and repeatedly tried to update, but it made no difference.
I noticed that for the last 2 updates at least, the file size is smaller than it used to be.
Can anyone suggest how I might fix this or at least roll back to the previous map?Last edited by LimestoneR7; 19-09-2024, 06:43 AM.
Well I havent had trouble but questions
Do you use a PC or a MAC
Secondly I found years ago that you couldnt reload a map over itself on the old RNS510. You could go back a version and then try again. Havent had to on a PRO so not sure. Have never seen the information screen you show
Also if you are d/loading the map which is about 26GB it pays to use a 64gb card as some brands wouldnt take prev maps as they were just a bit too big for the 32gb versions.
Lastly did you try the version above which Flipper Dog posted as that is the latest pro map and does work. Yes I see it says 373 but where did you get it from.Last edited by Guest001; 19-09-2024, 10:44 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by LimestoneR7 View PostI use PC.
I'll check tonight but I'm 99.9% certain my Card was 64gb.
I did use the version that Flipper Dog had, after first using the file from the international VW site that I have used before.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I used a 128GB USB drive that I've used before to update the maps. It was ExFat formatted. From memory the downloaded file was 15Gb and after unzipping with 7 Zip it was 19GB. Can anyone who downloaded the Pro map confirm those sizes?
It seems like my system is missing information to show any map detail closer than 40km in.
If previous versions are available to download, does the Pro let you install an older map?Last edited by LimestoneR7; 19-09-2024, 08:00 PM.
Ok just downloaded 373 from Flipper as above and yes its 15gb which is much smaller than they used to be. Why not go up to his January version and try using that It wont hurt Will either work or not. I use WIN RAR to unzip it to a HDD and then copy it to a card. You should have 3 lines on the card
MIB 1
MIB 2
metainfo2
Dont alter anything or it wont work Just load the lot and wait.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I downloaded the earlier version. The file size was 10gb larger than the current version.
I received the same error message. But....it all works! I can't explain it. I went for a short drive to confirm.
I'm going away this weekend so at least I will have some maps rather than none at all.
Hopefully the next update will work for me.Last edited by LimestoneR7; 20-09-2024, 11:49 PM.
Originally posted by LimestoneR7 View PostI downloaded the earlier version. The file size was 10gb larger than the current version.
Hopefully the next update will work for me.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostSo whats the update on this Is it working or not
It's all working on the same system as before so I can't see how the file compression could be more efficient than before, whilst provide the level of detail as in prior updates.
Maybe someone from VW reads this and might be able to figure out why I had the issues with the current map.
It will be interesting to see what the next map update holds.Last edited by LimestoneR7; 24-09-2024, 08:07 AM.
