Any aftermarket boot release camera will work.
There isn't one in particular I can recommend.
Something like this should work, you'd need to confirm that it is the correct measurements etc:
Crngiar Car RCA Rear View Camera Delay Timer Relay Filter for VW RCD330G Plus Passat Tiguan Golf Touran Jetta PQ MIB Conversion -in Cables, Adapters & Sockets from Automobiles & Motorcycles on Aliexpress.com | Alibaba Group
You will also need a digital delay relay (included in the above link, just make sure you select the correct boot release camera and relay) to use to connect it to the reverse light circuit, otherwise you can end up with flickering, and image cutouts when manouvering and changing between reverse and forward gears. The digital delay will 'debounce' by keeping the camera powered for 30 seconds or so after going out of reverse, so that if you go back to reverse again quickly the camera is already powered.
