Hi there,
I own a Tiguan tsi 125 2010 and recently installed HID lights. The lights were working fine for a day until last night when the passenger light went out. I first thought it was a blub and swapped it with a spare which didn't work. Then tired changing the ballast over however still no luck. Finally I tested the output of the light connector plug (prior to the ballast) and to my surprise there is no power. So the at the moment the drivers light works and the passenger light doesn't. Is there a separate fuse and or relay for each headlight? If so, where are these located.
Thanks
Thanks
