Installation of a Mk7 Multi-Function steering wheel + paddles into a Mk6
  • #76
    Originally posted by tigger73 View Post
    The solution as far as I'm aware is to buy a steering wheel for a Jetta or possibly current model Polo GTI that "looks" like a MQB platform wheel but is actually compatible with the "old" electronics. Don't buy a wheel out of a Mk7 Golf and try and install it into a Mk6. It wont work without sticking in some sort of conversion box to change/convert the LIN messages for each button press.
    There were a few sellers on ebay selling these Mk7 "look" steering wheels. Otherwise if you install a proper Mk7 wheel you have to be prepared to lose some functionality from the steering wheel controls.
    Just to add to tigger73's sage advice (and without wishing to steal his/her? thunder), here's a diagrammatic view of the reason why the mk7 steering wheel is fundamentally incompatible when retro-fitted to a mk6
    According to VW's material and as can be seen, in the mk7, the multifunction steering wheel is included in the car's network, whereas the unit in the mk6 is simply directly connected to the steering wheel assembly.
    So, while the multifunction steering wheel control unit J453 on the mk7 was previously a LIN slave to the steering column electronics control unit J527 (see E221 LIN wire), it is now connected directly to the diagnostic interface for data bus J533 as a LIN slave. As is shown in the picture above, the signals from the multifunction steering wheel are, as previously the case, transmitted via the coil connectors and the steering column electronics control unit, but for wiring reasons only. They do not have any effect on functions there (whereas they are part of the J527 functions on the mk6)
    Don
    PS: I wasn't aware that someone was offering a emulator box for the LIN differences! Sounds interesting- I wonder how it works?
    • #77
      Thanks tigger, thanks don.
      The OEM plus tuning loom gets everything working bar DSG and vagnostics in the U.K. have everything working except cruise control. So I remain hopeful that someone will crack it shortly.
      • #78
        I'll be starting a lin-lin converter project. So anyone with a lin sniffer are more than welcome to help! This is the only way to get it working and even the scirocco mfsw doesn't light up without this lin-lin translator so apparently a lot of people must be missing it?!
        • #79
          I have spoken to a couple of the guys in the UK that have Mk7 steering wheels working in a Mk6 and they are "plug and play". I am almost certain they are using the Polo or Jetta wheel that is based on the Mk6 platform. I have tried a genuine Mk7 wheel in my wifes Tiguan and it does not work. I've also compared the part#'s for steering wheels and the steering wheels that others are claiming work in Mk6 have different part#'s to Genuine Mk7 wheels.
          - Tigger73's 125TSI Build
          • #80
            Call me crazy- but i think the steering wheel used in the Mk6 GTI and R is one of the best looking and feeling steering wheels out there. The Mk7 wheel looks "thinner" and looks less chunky - im not a fan.
            • #81
              Dsgwhizza is in Brisbane and offered help re sniffer. Not sure where you are located.
              Jamesatfish is in Canberra and has also offered help
              • #82
                Absolutely happy to help if anyone wants to look further into this.
                We're in Canberra and have a Mk6 R and Mk7 R wheel along with the CAN/LIN sniffing tools, and we're more than happy if someone wants to come out and spend some time playing with them at our office. This is a project I was going to look into myself but unfortunately our other work commitments have pushed this down the priority list.
                • #83
                  my latest DIY project
                  more info major@hot.pl
                  • #84
                    Nice work spacewalker. I saw your posts on the Rosstech forum. Have you got that converter harness now available?
                    • #85
                      Originally posted by spacewalker View Post
                      If you can post up more info that would be appreciated. There have been a couple of us attempt this mod but been unsuccessful. There are a number of steering wheels that "look like" a Mk7 wheel, however have the electronics for Mk6. Can you please confirm the part number for the steering wheel that you have used and what modifications were required to make this work.
                      I have seen current model Polo GTI and Jetta steering wheels work in Mk6 Golf, however both these steering wheels/cars have the older electronics even though the steering wheel looks like a new style wheel.
                      • #86
                        I can vouch for spacewalker, he is one of the top VW electronics gurus around. Got my colour MFD for the Tiguan reprogrammed from him fully immo adapted including new key transponders, posted from Poland.
                        I can tell he's used the mk7 wheel (he is well aware of the mk6/mk7 lookalikes) and trust he has used some magic trickery.
                        I'd be curious to see how he did it! Sounds like it didn't even need a LIN bus converter?!
                        - 2011 Multivan T5.2 - 2,0L 135kW BiTDI. Mod info here
                        - 2008 Tiguan 5N 103TDI 4MOTION. Mods: RNS510 | Colour MFD | MFSW | LED tail lights | Mirror LED | Footwell LED
                        • #87
                          Module still nor ready to "share" ... .got some parts from china, and they are fu****** so need order new local
                          My MFSW is NOT a MK7...is a New Sharan/Polo/Caddy , simple run ETKA to see where that number go.
                          Please dont think that everything what look like MK7 must be MK7
                          The fact is new VW style MFSW looks this same, but electronic is not this same , and command / communication too
                          YellowLemon, here you are ....thx for feedback, now I can code 3D cluster if you want
                          Anyway - regarding MFSW I did new module, to translate command.
                          You can still diagnostic MFSW, and code it , all is almost genuine
                          What news my module have it:
                          Can be diagnostic via VCDS, visible in autoscan
                          Illumination working toogether with whole daschboard
                          Recognize MFSW number
                          Support MUTE and VOICE command (short press MUTE, long pres Voice command) - you have both !!!!
                          Can adjust illuminate individual (if you use MK7 MFSW with WHITE backlight, or you solder RED LED) you dont know the genuine MCD value . To reduce illumination you must play with resistors. My module can reduce backlight via coding , like dimming DayLight via CECM
                          Bad is: - ACC via MFSW not work , so can not be use for Passat B7 with ACC.
                          LIM/MODE not work because ECU not understand it
                          You can use any MFSW with ACC, LIM/MODE, CNL etc , module will convert singals to right options
                          I hope in February all will be ready , user manual / how to is out , and is just 5-7 wires to solder but something must be check before installation,
                          if somebody is interesting please mail me to MAJORatHOTdotPL
                          • #88
                            [QUOTE=tigger73;1148565]I seriously don't think the problem is the mk7 wiring harness. I've tried about every single wiring combination possible and have come to the conclusion that the mk7 wiring harness would work as-is. Though I ended up leaving it modified to the same pin-out as the Mk6.
                            What is going to be of most value now is to find out what the part# for the mk6 SWCM and also for the Mk7 button controller that the guys in the UK are using.
                            I'm not too concerned about illumination right now. Car mostly gets used during the day anyway.
                            Hello, i have instal a Mk7 steering wheels from Passat into Mk6 Jetta.
                            How did you make that horn is working? Illumination is working, also "OK" button turns the stereo volume down and the MFD screen left/right navigation changes stations.
                            • #89
                              Any updates on this gents? Would love An MK7 style DSG wheel for my MK6 Golf R
                              • #90
                                I finally got around to swapping in the MFSW with paddles shifters today. Ended up with a wheel from a 2009 R36, which I'm happy with despite initially looking for one from an R32. As most people seem to say, not a difficult job, though I was a bit nervous around the airbag. Fortunately I got the new code into OBDeleven just moments before my 2013 Nexus tablet decided to throw a tanty. Wheel feels good, and the shifters will be handy.
                                2007 Passat V6 FSI 4Motion Sedan | Reflex Silver | DBA Slotted Rotors | ATE Ceramics | Pioneer Car Play |
                                | Emblem Reverse Camera | R-Line MFSW w. flappy paddles! | Supernova Headlight LEDs & Parkers |
                                On the radar: Chrome switches, engine mounts | Living vicariously through everybody else's mods!
