Hi guys,
Really need your expertise here.
I bought a MY2012 T5 Caravelle (7E)
Bought;
1) RCD510 (5KO 035 190)
2) 9w7 (5K0 035 730 D)
3) genuine harness and mic
Installed it all in (wasn't too hard)
The radio works well, even the OPS shows the rear sensors on the screen with no VAGCOM coding.
however when i tried to change the long code for the CANBUS 19 to include 77 it wasn't there, in fact there were only 3 Bytes to choose from....
Here is a fresh scan, please HELP a newbie!!!:
Wednesday,20,May,2015,19:34:41:54149
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Ross-Tech: Home
VIN: WV2ZZZ7HZCH049920 License Plate: VAO000
Mileage: 85440km-53089mi Repair Order: 33333333
Chassis Type: 7H (6N0)
Scan: 01 02 03 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV2ZZZ7HZCH049920 Mileage: 85440km-53089miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CCHA) Labels: 03L-906-022-CAA.clb
Part No SW: 03L 906 019 DH HW: 03L 907 309 K
Component: R4 2,0L EDC H43 9133
Revision: 26H43--- Serial number: 00000000000000
Coding: 01254012231400080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20TDI01103L906019DH 002008
ROD: EV_ECM20TDI01103L906019DG.rod
VCID: 74E73EF5DF68AA817A7-8021
2 Faults Found:
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [032] - Signal too High
Intermittent - Not Confirmed - Tested Since Memory Clear
4715 - No Communication with Instrument Cluster
U0155 00 [032] - -
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743) Labels: 0BH-927-711.clb
Part No SW: 0BT 300 045 M HW: 0BH 927 711 C
Component: DSG DQ500-7F H05 1712
Revision: 00H05V01
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VN75.rod
VCID: 3F8DA1D9A6AE39D9575-806A
No fault code found.
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 H HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0107
Revision: 00H43001
Coding: 208724AD09A8049E24AB9073AA5E10
Shop #: WSC 02756 790 49152
VCID: 377DC9F9869E01999F5-8062
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
Part No SW: 7E5 907 047 BA HW: 7E5 907 047 BA
Component: Climatic-T5 H19 0404
Revision: 00001009
Coding: 0000000402
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 6FED3199B64E8959875-803A
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 H HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0251
Revision: BO047001 Serial number: 0429 269110622
Coding: BAB879380E21201300200810242B8CD40000410F6004000030 0000000000
Shop #: WSC 35683 123 104857
VCID: 3979CFC1B08A17E9691-806C
Subsystem 1 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-801.CLB
Component: J386__TSG_FT 002 3311
Coding: 010000
Subsystem 2 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-802.CLB
Component: J387__TSG_BT 002 3311
Coding: 000000
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
Part No SW: 7E0 919 475 D HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47301120800438
Coding: 118101
ASAM Dataset: EV_VW75XParkAssis4K A01006
ROD: EV_VW75XParkAssis4K.rod
VCID: 3365FDE99AE6EDB9A3D-8066
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag00B H06 0013
Revision: -------- Serial number: 003HL007WDMT
Coding: 000000000000000000000000000000003042
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
ROD: EV_AirbaVW10BPAVN750_SK12.rod
VCID: 3561C3F19492F3898D9-8060
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 7E0 920 860 E HW: 7E0 920 860 E
Component: KOMBI H04 0305
Coding: 160A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
VCID: 2A5BE08D4D2CAC7110B-807F
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H47 0251
Revision: BO047001
Coding: 042300
VCID: 70EF32E5A37096A19EF-8025
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0305
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6ADB208D8DAC6C71D0B-803F
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3531926
Coding: 0800020001
Shop #: WSC 10580 123 65156
VCID: 62CB48AD7D9C343118B-8037
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000158754925
Coding: 410D000100000000
Shop #: WSC 02756 790 00000
VCID: 306FF2E563F0D6A1DEF-8065
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 D HW: 5K0 035 730 D
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662471347
Coding: 0A00000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 264314BD59348811343-8073
End-------------------------(Elapsed Time: 02:22)--------------------------
Bought;
Ross-Tech: Home
2 Faults Found:
U0155 00 [032] - -
Revision: 00H05V01
Coding: 0014
Revision: 00H43001
Revision: 00001009
Coding: 0000000402
Coding: 010000
Coding: 000000
Coding: 118101
Coding: 160A00
Revision: BO047001
Coding: 042300
Serial number:
Coding: 000000
Coding: 0800020001
ROD: EV_UHVNA.rod
