1 new thing I noticed is that when in reverse you can change the brightness contrast etc. I don't think that was in the firmware previously.
Sent from my Galaxy Nexus using Tapatalk
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
I got some monsun.exe error messages as well. One thing i can tell they fixed is the car showing up when doors are open, it is now a passat, just like the one when OPS is engaged.
By the other hand, I just got an email from AudioSources with the original DNS610 production unit FW, you can download it from here:
I haven't tested it yet, i will have to wait till i get home, so any feedback will be appreciated. They told me they are releasing a new update next week.
Offtopic: Got curious and searched for Boy & Bear, since i've never heard of them, and i'm liking them a lot.
Edit: I have jsut flashed, and it seems it is missing some files, llok at the pictures:
Anyone else have a problem where the phonebook contacts get deleted every time the unit is reset? Not sure if its the new unit or just the firmware. Im going to try a few other firmwares and see if I can narrow it down.
One thing I that keeps happening is the MPU flash keeps going over and over several times before the MCU reset will start. It runs ok, then you reset the unit and pit the card back in and it runs again. Then you pull the card and reset again and it starts the MPU flash again with no card in. Replace the card and it conpletes then it will usually run the MCU flash finally. I'll test some other versions and see how I go.
Love your work matiasg85, at least someones trying to look after us!
I will give it a run and see what happens.
Can't be any worse.
Good to hear you like Boy & Bear, no bull**** Australian music!
MPU on that version is 16bit, I believe the SD/CPU issues got a bit worse when they went to 32bit, but the 16bit old version still had it. The older december firmwares also had the CANBUS/crashing issues, that's why I would be hesitant about using an older version.
Sorry, but what is the "Previous Stable Firmware"? Can i have it?
Previous stable firmware is the December 28 firmware I was talking about Link is in the spreadsheet. I'm not sure that it was made with the 610 in mind though? Either way I'd use the latest april firmware, or wait until the new version with the fixed SD/CPU issue?
Moda, it may not have been made with the 610 in mind but it works a hell of a lot better than the latest firmware when it's in my 610.
I think I might be doing something wrong, whenever I flash de older mpu I loose the reds and most of the sprites as in my previous pictures. Can you give me all the files you used to flash and your exact procedure?
It looks like i wasn't updating the bsp (The black screen with "colorous letters", because i was using a 64GB card i was unable to format as fat. Now it is working.
Matiasg85, what I did was start with the old firmware and then after the first part is loaded and you need to remove the SD card
the I loaded on the new firmware you were sent and used the MCU from that.
So put the december update on an sd and start putting it on the unit.
The when it asks you to reboot, shut it down and go and load the latest update
you were given from AS to the sd and finish the procedure with that.
Did you notice any improvement? Is the MCU in the file i provided newer than the april's firmware? I will have to give it a try tomorrow. GPS is now usable, loudness is working again, and i like much better the "old"interface, with the "3d" bar in the USB/Sd player.
