This is a sticky topic.
  • hi,
    Yes it is Europian version. I did post wrong one (copy past fout). and also i see that i am on the wrong topic. By the way thank for quick replay and i ll try to find a right topic without posting new one
    Originally posted by Hillbilly View Post
    Did you install the European version as the 4120 for Australia partitions the HDD differently and it wont then load a euro map as the partition is too small
    By the link you have listed it appears you have the wrong firmware version if as it seems you are in Europe I see from your Newbies post you are in Holland so this will be the wrong version I would think. Someone may be able to point you to where you can get the correct Euro version
    • Check the vwnavi forums:
      Unofficial 272x software and SWL recovery CD
      • thanks a lot
        • Thanks for the great write up, detailed instuctions and the .iso. My unit is now running the latest firmware and seems a little snappier, also loving the custom boot screen I got on there.
          Easy as pie to do this update, cheers to all involved.
          • Question... have there been any updates since the 4020 release? I feel like I have been on this version for a lot longer than the time spent between other versions..
            • Originally posted by vraptor View Post
              Um, yes. Either scroll up a bit or go to the first page in this thread.
              2011 Octavia RS TSI DSG wagon
              2004 A4 1.8T CVT Sedan
              Previously:
              2007 TT 2.0 TFSI S-tronic
              • 4120 link is in the original post Adds RDS and a male voice.
                • Originally posted by Shred View Post
                  Sorry my bad, I meant the 4120 update.
                    In that case not really There is a 53+++ version but is apparently for Euro cars I think and not worth worrying about here
                    • If you are keen I can give you the link. No feature advantage as it is for dab boards.
                      Sent from my HTC One using Tapatalk
                      • Sorry for spamming this thread with a specific question. The guide is quite clear and well written, but I'm having trouble working out whether to load the 38xx series or 412x firmwares.
                        My RNS 510's part number is 7L6 035 680 B
                        it's in a late 08 (potentially MY09) Touareg.
                        HW-Version is H03 and
                        SW-Version is 0902 from long pressing on the set up button.
                        HW Radio version is 0004
                        The model is also mentioned here:
                        http://www.my-gti.com/549/volkswagen-rns-510-versions
                        but I'm still not clear on what version of software I could load!
                        • I brought my B series unit (now sold, along with the car) up to the latest 38xx firmware and was happy with it.
                          Any gain from later firmwares appears minor, at best.
                          • For you Mac folks that want to do it on their Mac's.
                            I've used Toast Titanium.
                            Once you have downloaded the firmware, RIGHT CLICK and open with Toast Titanium.
                            Select CD, click the RED Button (Burn), Speed Type: 1x.
                            And should take around 10-15min for the completion and follow as per instruction in the first post.
                            • Originally posted by superhaak View Post
                              3810 is the highest you can go with a Touareg
                              • Please help to clarify my query:
                                I got a 2011 Passat with built-in Satnav RSN510 with version as below
                                Part number: 1T0035680C
                                Hw version: H50
                                Sw version: 2840
                                which reliable firmware version that I can upgrade without any re-coding, etc..? 4020 or 4120?
                                Thanks
