RNS Firmware 4020/4026/4028/4024 (C6 - C12)
  • #16
    Alright guys. I've got a modified 4020 working with 90/5/5 partitions, VIM and the test menu pre-activated.
    Links will follow shortly. Waiting for it to all UL.
    And Steve, your 3810A_NORU with all the same trimmings is ULing too.
    • #17
      Noice one. What was the issue do you know?
      • #18
        The CRC that was being generated didn't appear to have the right value. I used one that JS sent me and it worked. Not sure why my SetConfig was throwing out a dud. Perhaps I just missed a small detail. I don't know, but I made a .ISO of the disc that I used which worked, so there is no room for error there.
        • #19
          Sounds more like they have changed the crc16 calculation used to protect the files.
          • #20
            4020 with 90/5/5 partition – Video In Motion fix – Test Menu enabled below.
            Same warning apply to this as the original SWL CD. Check your unit for compatability as described above.
            This has been installed and is working on a 0xC801 / 0006 based unit (True C)
            I am not responsible for any damage you may cause your unit using this .ISO.
            Links as promised…
            Rapidshare – Part 1
            Rapidshare – Part 2
            Rapidshare – Part 3
            Rapidshare – Part 4
            Rapidshare – Part 5
            PS. Doug, if you're reading this – it will work for your unit too.
            • #21
              Links as promised…
              Rapidshare – Part 1
              Rapidshare – Part 2
              Rapidshare – Part 3
              Rapidshare – Part 4
              Rapidshare – Part 5
              Thanks johnc, will try this tomorrow, i bought mine as a Version D, its showed different versions on VCDS and test menu (due to firmware?) but im assuming that because it has a 40gb hard drive its the version D. (and that i installed firmware 3xxx before it was modified etc).
              • #22
                Any chance of getting that uploaded to MediaFire as well so that it doesn't take an hour to download? (/hyperbole)
                Audi A3
                • #23
                  It took me more than an hour to upload it, so I think you'll live.
                  • #24
                    Hehe
                    I'm surprised people still use RapidShare or those other sites that make you wait to d/l. I wasn't phased at all when MU was taken down.
                    Audi A3
                    • #25
                      My private server is full and I didn't want the extra traffic anyway. I spent quite a while getting it to work, with numerous tests, and then uploaded it. I would have much rather been doing something interesting I assure you.
                      You can always share your thoughts here
                      • #26
                        Originally posted by Ryan_R View Post
                        Hehe
                        Use JDownloader, great software, and just queues up the files!
                        • #27
                          Well played, John
                          Audi A3
                          • #28
                            Cheers John,
                            loading it onto my RNS now,
                            MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                            2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                            • #29
                              Thanks also John!
                              Anyone had any success loading onto their C Unit?
                              Keep getting SWL Error @ 30% or specifically 14% into installing APPL.
                              MY11 Tiguan 147TSI (SOLD)
                              • #30
                                Originally posted by aussietig View Post
                                Thanks also John!
                                you trying to load 4xxx series?
                                Not sure if it will work on a B or C unit.
