If you want the 3xxx RNS firmware and POI's to work.. look here.
  • #31
    Its called Setconfig for RNS510, its written in part by josi from the vwnavi forums.
    Has a hardware lock the same as VCDS. The customizing is limited to which modules are loaded, custom boot image, plus changing any of the script files whilst maintaining a valid CRC. There is a pro version as well which has more diagnostics available (ie you bench the RNS510 and hook up directly to your laptop with the supplied cable) and do backups of various files direct from the unit etc. You can also make custom disks that swap around various files to allow newer firmware to run on older units.
    Would be happy to look at whats on the BMW nav disk if someone has access to one and see if we can hack something together. I've played a lot with iGo map data however I understand they are much easier to work with than the 'OEM' nav setups. Nothing is impossible though
    Have come across a 'backup' of the BMW disk will take a look and see what we can do...
    ---------- Post added at 12:28 PM ---------- Previous post was at 11:27 AM ----------
    Ok so the structure on the disk is the same as the VW files however the one I found is 2009 data also.
    Need to see if there is a newer version available...
    • #32
      i know that the bmw ones are able to be bought, and they are not too expensive, we could all chip in for the latest?
      • #33
        I've done a little reading and there are a few people complaining that the 2011 map disks they bought are just relabelled 2010 disks...would need to check that there is indeed a v17 (2011) disk actually available. Sound like BMW Aus is not much better than VW Aus with updates...
        • #34
          V16 (Red Disc) info available here BMW High 2010 AUSTRALIA V16 (red disc)
          MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
          2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
          • #35
            Thanks FJ Steve, but unfortunately that appears to be the same mapping data as we already have (ie 2009 data)
