During my initial investigations when trying to modify the partition scheme I tried half a dozen different clone tools.
Also tried manually editing the partition table with a hex editor.
However the RNS uses a proprietary file system that none of the tools I tried was able to recognize: the Vienna Flash File System.
Its possible that this Clonezilla tool may work I am not familiar with it personally. However I spent a great deal of time going down this route until deciding it was a fruitless task and then moving on to the much easier method that I discovered actually works - namely modifying the firmware load scripts.
An SSD will not make any difference to the speed of the unit except when browsing your music library.
