Summary of Bluetooth Options for RNS510 & RCD510
  • Originally posted by Ryan_R View Post
    fwiw I don't have those icons either, actually forgot about them when I upgraded.
    Yes they are trivial and it is hardly worth the effort. But I like a challenge and I a know there are others who keenly want a fix. You don't have a copy of your pre upgrade phone module coding in an old scan do you?
    Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
    • The car never came with bluetooth -I retrofitted 9W3 (which didn't have the icons), then swapped with a 9W7, then swapped again for a newer 9W7 when diagnosing issues with my new phone. At no point have I had those icons.
      Audi A3
      • Mine that came with the car does have icons though.
        Will get the long code next time I boot my laptop.
        • Stock bluetooth in MY12 Golf R with RNS510:
          Address 77: Telephone (J412) Labels: 7P6-035-730.clb
          Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
          Component: TELEFON H09 2730
          Revision: 1B001001 Serial number: 0000766064xxxx
          Coding: 0A01000000010101
          Shop #: WSC 01357 011 00200
          ASAM Dataset: EV_UHVNA A01015
          ROD: EV_UHVNA_VW36.rod
          • interesting that - the battery level.
            mine's never displayed it, be it in rsap mode or hfp mode.
            i've got the 9wz bt module.
            • Originally posted by tonymy01 View Post
              Thanks for that tonymy01. I checked the differences between our coding and there is nothing untoward in it. Your language is North American mine is English. You have voice operation inacative, so I set mine the same. You have the three button keypad, I do not. That's about it.
              I did notice measuring block "009 status of phone" on mine is perennially Unknown.
              Next time you hook up your VCDS could you PLS take a peek and see if that block is populated in yours? I thought perhaps this block might display a % on yours like the telephone field strength is correctly doing. OTOH it may just be offhook/onhook indication.
              • Says not connected for mine, even though I know it is...
                • i have a 9w7 unit and when i first installed it 1.5 years ago it was working perfectly with BT streaming, all icons showing etc on my white mfd and i use an iphone but since upgrading to IOS7, everytime i get a notification on the phone, it will force the headunit to be on BT streaming mode no matter which mode i was in previously (FM, MDI, CD)
                  so now when i get in the car and the phone syncs up, i have to unpair the phone under "media" on the mfd which leaves the phone connected but no media available.
                  Is there a better way to do this? can the bluetooth module have the software upgraded or something?
                  Thanks
                  2010 Jetta 125TDi DSG
                  1994 Golf VR6 Manual
                  • Have a look in the Settings menu of your head unit for something along the lines of Bluetooth Autoplay
                    Audi A3
                    • I've got the kufatec fiscon bluetooth module installed in my rns-510 unit but everytime i get a message or unlock my iphone, it pauses the music on the unit. Does anyone else have this issue?
                      • Hi all. Digging up an old thread again. Reading through has been massively helpful. However I'm trying to find any info from someone who has installed one of these 9wZ kits: http://rover.ebay.com/rover/0/e11400...OC%3AAU%3A3160
                        I have a 2008 golf TDI with red highline mfd. Looking through this thread I can't find anyone who has installed one of these "FIS kits". Do they work as it says in the ad? It sounds perfect for what I need.
                        Thanks for any help
                        • Hi, I wonder if anyone can help me.
                          I recently installed a RCD510 to replace the RCD310.
                          Whenever I select BT Media it defaults to the music player on my phone and automatically starts playing it.
                          . If I change it Soundcloud, for example, it will play, but if i leave the car and come back it goes back to the music player. It never did this with the RCD310
                          Also, if I'm streaming music from the phone and then play a game on the phone, the sound effects of the game get sent to the Radio.....(which is really annoying - I Can't adjust the volume of the game because it now adjusts the BT volume, which it never did before )
                          I can't see anywhere on the RCD510 (or the phone HTC One) where I can set the order of players. BY Autoplay is unchecked
                          Any ideas? The Bluetooth Module is 9W7
                          • See if you preferred music app has Bluetooth streaming settings. I use PowerAmp Pro and it has a setting to become the default AVCRP handler.
                            Default behaviour is for all sound data to be sent to the car while connected. It is using the 'headset' bluetooth profile. Imagine sitting on the train listening to music through wireless headphones and then all of a sudden everyone else hears the audio from the game you just launched. In any case, have a look through the app store in case there is a utility that can manage bluetooth audio streams. There won't be anything in the car that can change this.
                            Audi A3
                            • Thanks Ryan. None of my players have that option. I've downloaded an app called Media Button Router which looks like it might be what I'm after.
                              I'm curious as to why this did not happen with the RCD310 - no re-coding with the RCD510, no change to the phone etc.
                              • Guys, apologies for the necro...
                                Have read through a bit of this post but it's pretty long. Still got 30 pages to go...
                                Did anyone figure out why some cars got full song title and steering wheel controls, while other just got "bluetooth audio"?
                                I have bluetooth module 5N0 035 730 D and wanted to see if replacing it would give me full song title and steering wheel control, but have not found confirmation that it is the bluetooth module that is the reason for this before shelling over the cash.
                                '10 Reflex Silver mk6 GTi, Xenon lights, Sunroof
                                Mods: R LED rears | Door lights | Underseat Drawers | Retro MDI kit | Retro passive TPMS | Retro PDC | Retro RVC | Retro Satnav | Retro 9W3 Bluetooth | ED35 bodykit | 18" "Durban" OEM wheels | S3 jack pads | S3 intercooler
