Auspack Sat Nav/ DVD system
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
I am sure I found a very good photo guide on the VWVortex forums, but cannoit now locate it.
You might try this link which is a rough guide.
The only tools you require is a 20TORX and a flat blade screwdriver.
In the above link, start at the Radio Removal section.
A loose guide is
1. Remove the Light Sensor (no screws. Just prise it up)
2. Remove the 1 screw under the Sensor
3. Remove the grill (No more screws. Just prise it up carefully)
4. Remove the 2 torx screws holding the lower panel. Then prise it up.
5. Remove the 2 screws on the front vent, and gently prise it away from the dash.
6. Remove the 4 screws holding the radio in place.
7. Lift out radio, and unclip Can connector.MY22 Tiguan 162 Elegance
Sound and Vision , Sunroof packages
Fireball Graphene Butterfly ceramic coating
Thinkware U1000 dash cams
Hey guys, managed to dumb thumb it with no real effort.. All I got to fig out is how does the TV antenna get connected
Have any of you guys used it ? I'm thinking of getting a small STB setup in the boot area, under parcel shelf and connect the tv antenna to that.. Mount it on the rear parcel shelf.. Umm dunno if its gunna be worth the effort
Still, gotta run the reverse camera cable, might as well kill 2 birds ...
But thanks guys
Muchly appreciate the responces
Tim
