VAG-COM scanning, who can help
This is a sticky topic.
  • @Deadly_headmen : Hi. hmm..... huh - you want to use VCDS/OBD11 to change the module Baud rate on an Amorok (which I assume is built on a MQB platform - like the mk7 GTI)?
    Please tell us (meaning me) how this is done - thanks!!
    Don
    • The long code you refer to assumes you have the correct lin converter soldered onto the steering wheel control module.
      This is a custom board and as far as I have seen is suitable for Pq35/46 which have a steering wheel control module seperate from the BCM.
      In pq26 (polo, Amarok, Transporter) this steering wheel control module doesn't exist so the converter would need to be somehow integrated into the BCM and I think that would be much more difficult.
      Sent from my SM-G960F using Tapatalk
      • Hi there,
        Just bought some LED headlights from supernova to replace my halogen units. I understand that the mk7’s with halogens are coded to dim the drl lights when the low beams are on. Was wondering if anyone in the SE Melbourne area would be able to fix this so the drl’s stay lit as normal when the low beams are on?
        • Originally posted by Michael_g17 View Post
          Hi there,
          Did you enquire about the legality of fitting these before buying them
          Are LED Car Headlight Bulbs Road Legal? | LED Upgrades | PowerBulbs AU
          • Originally posted by Hillbilly View Post
            They are legal yes. The whole headlamp unit is being replaced, it is not just led globes going into a halogen socket.
              Michael: Hi. I need to preface to my response below with a statement that I intend absolutely no offense by my words (I simply seek to inform)!!
              I suspect that @Hillbilly question about road legal goes further than the issue of swapping bulbs; he is really asking whether the entire retrofit process is compliant with the Australian Design Rules - which mandates (in addition to other requirements) the need for peripherals like self-levelling system and headlight washers when the lamp intensity (i.e. Lumens) exceeds a threshold value.
              I'm not sure where your over-all supernova project sits in terms of the ADR - but like @Hillbilly, I suggest that you satisfy yourself that the car remains road-legal (for lots of reasons related in the main to insurance coverage, legal liability and just plain safety for yourself and the other cabin occupants - and the drivers of on-coming cars)!!
              Yes, lots of folk blithely ignore the consequences of these projects on the basis that their decision will never be brought to account. And maybe the probability is that the decision to drive an un-road-worthy car won't ever be brought in front of a court - but the last thing that you want is to have to justify to a Judge why your desire for fancy LED headlights has resulted in harm (or death) of another human!! I don't apologize for raising such a stark example - I just want to ensure that your decision regarding how to proceed is informed!! And frankly, since you likely will be driving in Victoria - I don't want to be the on-coming driver that could be blinded by badly aimed low-beams!!
              So - as for your original question about DRL brightness after dark (which ironically is the very same issue as the blinding effect to on-coming cars from the low-beam lamps if a self leveling device isn't fitted) - the answer is "it depends"!
              The sad fact is that despite EVERY manufacturer of after-market headlights claiming that their products are OEM - none are!! Take your case as an example, your incandescent fittings have a 10 x pin connector that mates with the factory fitted wiring loom. But OEM LED headlights have a 14 x pin connector. So unless you run additional wires back to the controlling module, they won't be OEM installations.
              More than likely, the supernova units will either have a non-OEM 10 x pin connector, or you will need to install a cross wiring harness (which again is not OEM).
              The reason for highlighting the non-OEM nature of your project is because the answer to your question depends on each manufacturer's particular design. If it can be done at all - I've seen after-market Chinese headlights in which the DRL can't be dimmed because of non-OEM electronic circuitry inside the fittings themselves!
              Don
              PS: the other interesting aspect of this project for someone responding to your plea for assistance is the very thorny question of what liability they assume for participating in the creation of a potentially un-roadworthy vehicle.
              I'm not a legal person - so I don't know. But my fear is that if ever the loose stools in the brown-stuff and the proverbial fan blades meet - anyone with potential liability will be seeking to discharge that liability onto someone else!! (I'm reminded of the truism "the person who smiles in a crisis always has someone else to blame"!!).
              If you are using a professional business for the installation, then the paperwork will likely be covered with legalese denying liability. But for a private individual with a diagnostic cable and a kind, but naive desire to help - maybe it's different (again, I don't know - but the low risk position is clear)
              • Thanks for the info Don, I’ll continue to look into it.
                • Anyone able to help with some vcds action in Brisbane area?
                  I need to do a DSG clutch adaptation to hopefully get the clutches to start fully disengage on stopping.
                  My OBDeven won’t do it on my car 🤦🏼*♂️
                  • Hi Guys,
                    Anyone in Adelaide can help with the coding for a replacement Body Control Module?
                    Looks like it might be the cause of my headlight issues.
                    I have the instructions.
                    Remotes need re-learning etc.
                    Thanks
                    • Assistance in Melbourne Northern suburbs please
                      New to modern VWs. My Touareg has a few issues and I need to do scan to try and sort them out. I also have an airbag fault as a result of removing the steering wheel. Any assistance appreciated. I'm in Brunswick and happy to buy, hire equipment or just pay for someone's assistance. Cheers
                      • Hey guys anyone able to help me out with some coding in Sydney. Parra area. I have the vcds just not the experience to want to tackle things alone as yet. I’d appreciate any help guys. Feel free to code your car if needed with my vcds if you don’t have one.
                        Thanks fellas
                        • Anyone in Christchurch New Zealand that could help with a scan of my MK7 golf that has a stutter in 6th gear when accelerating and also it lurches when cruising along at 50kmh?
                          TIA. Nathan
                          • Can anyone help me. Essendon area. Mk6 golf wagon. Need to code out bulb error after changing to LED. Also check rear door coding for led puddle lights. Anyone able to help?
                            • I have the VCP cable that can modify the PQ35 BCM for LEDs.
                              I am down the Mornington Peninsula way if you come this way; otherwise, I will probably be up that way in the next few weeks.
                              • Mig. Hey thanks. I might wait until you’re back up this way if ok? Could you please PM when you’re up this way.
