Originally posted by Frostee
View Post
Polo GTI APR ECU Upgrade
How's does the current torque limit work? Is it just settings in software? If you didn't limit the torque what and where would the peak power on the standard engine be?Black 5dr, Polo (6R) GTI - APR CAI & IC, Milltek TBE, APR Stage2, XDS-2, ABS-2...and babyseat
Sorry Guy_H. Lazy effort on my part.
Let's start with thge current torque the engine produces. I see the tiorque curve is dead flat over a wide range at 240nm. Obviously the engine can produce more torque than this but it is being capped at 240nm. Do you know how they cap the torque? Is it capped/controlled by the 7DSG software?
CheersBlack 5dr, Polo (6R) GTI - APR CAI & IC, Milltek TBE, APR Stage2, XDS-2, ABS-2...and babyseat
I am by no means an expert; but I believe it would if they could prove that the chip in some way caused non-standard wear and tear; i.e. extra boost which shortens the life of the turbo and engine components. The good thing I have read about on the APS website is that the code they use is invisible to the factory computers, so they shouldn't know it is there in the event that something does go wrong.6R Polo TDI; DSG
This is a twincharger Jetta 118TSI with 7 speed dry clutch DSG - power & torque curves based on measured numbers. We expect the Polo to be pretty similar to this.
Originally posted by Frostee View PostDoes this type of chipping void warranty?
Some software comes with extra engine / drivetrain & breakdown warranty (at a cost) - such as Oettinger: Index
Discuss you options with your nearest tuner!
Thanks. As far a physical changes it seems your focus will be on the turbo and exhaust. I for one would also be interested in squeezing a bit more our of the SC. Can you explain more fully why a larger pulley will not be useful? In addition to adding more SC pressure wouldn't a larger pulley mean the SC would be able to run to higher engine revs before being cut out for the turbo to take over?Black 5dr, Polo (6R) GTI - APR CAI & IC, Milltek TBE, APR Stage2, XDS-2, ABS-2...and babyseat
Originally posted by weedub View PostThanks. As far a physical changes it seems your focus will be on the turbo and exhaust. I for one would also be interested in squeezing a bit more our of the SC. Can you explain more fully why a larger pulley will not be useful? In addition to adding more SC pressure wouldn't a larger pulley mean the SC would be able to run to higher engine revs before being cut out for the turbo to take over?
Originally posted by cme2c View PostAny handling/braking upgrades in the pipeline Guy? Got to put those Clio 200s in their place!
Any development news guys?2010 Polo GTI - 5dr Flash Red
Completed upgrades: RNS 510 install, Retrofit MDI, Bluetooth
Planned upgrades: Amp, 3 way speaker install
Planned mods: APR tune, Brembo brake upgrade
