APR ECU Upgrade MK6 Golf - Customer perspective
  • Originally posted by Guy_H View Post
    3 laptops, 3 x hex USB + Can cables, connect directly to the can wires. There is no limitation on the can bus talking to different modules, the limitation is 1 laptop / 1 USB connection / 1 VCDS cable per laptop.
    So if you connected VCDS cable to hub and hub to 3 laptops with VCDS program, that wouldn't work?
    • There are USB splitters, to share a device with 2 PC's (but only one at a time, not simultaneously).
      Audi A3
        Thought as much, I'll leave that stuff to the experts
        • Originally posted by Idle View Post
          Nope, the cable is a dongle in itself so I cant imagine that working (nor can I imagine anyone trying to sync the data!) - all hypothetical really.
            Not to mention if it was possible to log multiple sources with a single cable, I'm sure the VCDS software would be updated to allow such.
            • Correct, I'me sure Uwe would love to have the ability to do that!
              • Pretty sure I worked out why my 98 Ron tune spontaneously stopped working without me switching anything. At some point I have had a fault in my Ignition switch that spat "Electrical Fault in Circuit - Intermittent" messages on four separate terminals. When this occurred it appears to have interrupted power to the ENG ECU. Cutting the power to the ECU means the the APR software will default to program 1 when power returns. In a standard installation this is Stock mode.
                So all I needed to do was re select the 98Ron program in position 2 and all is fine and beaut again. So a power interruption in the car resulted in the ECU reverting back to the stock program. While I was aware the 98Ron tune performance gains were missing and the car was driving like stock, I was not prepared to try switching it back on. I wanted there to be no doubt that I had not meddled with the switching in any way to cause the fault.
                So nothing wrong with the APR Tune. The cause appears to be a transient fault in my car that had the undesired side effect of deselecting the tune. Happy camper again.
                Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
                • Nice to hear. I wish I could set 98 RON as the default program.
                  Audi A3
                  • So Ryan_R, do you have a VCDS cable - could it be you have the same ignition issue that logger has?
                    • I do, but I seem to be switching to Program 2 nearly every time I start the car now, with unpredictable results when I lean on the accelerator.
                      From my limited experience, it seems the best way to get the most from the car is to just drive it in whatever mode it is for 20 minutes to allow the engine to warm up, then when you get to a road where you want a bit of performance, pull over, park, switch to Program 2, and head off again.
                      I'll run a fault check when I get a chance.
                      Audi A3
                      • [part QUOTE=logger;600533]Pretty sure I worked out why my 98 Ron tune spontaneously stopped working without me switching anything.......
                        Have just finished reading this whole thread.....phew!
                        Your posts were very informative and as I read them I kept hoping for a favorable
                        outcome regarding the issues you were experiencing.
                        Sounds like all is now good with your 118 TSI so just wanted to say that's great
                        news and you must relieved
                        Current ride..MY10 Golf MkVI GTI | 5 dr | CW | < DSG >| Leather| Dynaudio | Sensors | Tint | R tails
                        Current ride...MY12.5 Polo 6R GTI | 5 dr | CW | Xenons | Alcantara Leatherette /4
                        • I haven't done any program switching for a couple of days and mine seems to be more stable now as well (has at least lasted for 6 starts or more)
                          Audi A3
                          • I've had my Stage1 tune for over a month now and the only times it's felt like it was "dropping out" of tune was in the first week after I had it done. Very odd. It was 40C in Perth today and it still felt like it was pulling hard. I'm continually amazed at how much torque it makes below 2000 rpm after the reflash.
                            Golf 118 TSI DSG, white with sports pack.
                            • You know how what I just said a couple of hours ago. Not taking anything back, but I went to grab some take away and the car was ferocious in it's response to the accelerator (I nearly flew out of the driveway (it's uphill)). Still haven't touched the cruise control stick.
                              Audi A3
                              • Originally posted by Ryan_R View Post
                                Hope all good with yours too now Ryan_R
                                Maybe the cooler Melbourne summer weather tonight helps?
