It Begins: The S3 1.8T into my '85 Mk2 GTI
  • Thanks.
    I have told QPEng they must sort it out with the tuner as they are now talking tech jargon that makes no sense to me really. I'm over it.
    I went qpeng because at the time of planning the project (4 years ago) it was the only way I knew of at the time to keep the original mk2 clocks etc, and my knowledge of ECU upgrades and tuning was nil. Also, the only references I had of the system at the time were from UK customers who never had these issues for some reason.
    The next time it goes on the dyno it will be with qpengs help via skype. If it doesnt get solved, it gets haltech.
    I'm guessing Autodata is useless now that qpeng have already modified the harness???
    I'll keep you all posted.
      hey Wade, there was a 2L S3 motor on ebay last week.
      isnt it about time you considered upgrading??????
      Yep that is funny dude. I'll put aside some time to laugh when this is all over and my credit card has some more meat on its bones...
      • wade i have the qpeng pin outs, keep me posted on whether the Haltech plugs in directly to the Qpeng plug i would consider this too. The knock sensors would need to be put into the plug I assume.
        90 GTI Mk2 1.8t soon to be with GT28rs
        • Originally posted by tommymac View Post
          I think the haltech unit with the same plug is an older type ecu that isnt very flexible with its tuning parameters, and its being phased out too.
          Do you have a diagram or something of the qpeng pin outs you can post up here?
          Cheers,
          Wade
          • wow
            wade
            What an epic thread, read it from start to finish over a week at work, top effort dude. I also have no prior knowledge and reading this inspired me that there is a lot can be done if you have common sense and hard work ethics.
            Hope everything works out for you with the ecu and am eager to hear everything’s aok.
            • Wow. The plot thickens as the tuning gets more mystifying!
              The tuners skyped up with the qpeng guys who were very helpful and showed him how to best use the system. After tweaking around with the settings and richening the mixture, etc it has not changed the leaning out issue, which in turn has led them to go back to looking at the fuel system!
              Apparently, if you gradually apply the revs it doesn't lean out, but under load and with 100% throttle on the dyno it leans out on boost???!!!
              I thought 'ok, last thing left to do is delete the digifant II fuel accumulator/reservoir still sitting there'. So off it came, and guess what? Absolutely no difference! AAAAAARRRGGGGGGGGGHHHHHHHHH!!!!!!!!!!!!
              The ONLY thing left that I can possibly imagine that is restricting fuel flow now could be the fuel filter (which is a digi II RV spec one). I'm going to make a dash back to work tonight to pop in an S3 spec one and see what happens.
              So far I have tried;
              - new fuel tank and brand new VDO VR6 fuel pump
              - new VDO fuel pressure regulator
              - new fuel filter (mk2 GTI RV spec)
              - ECU map adjustment
              If anyone can think of any other possible causes, PLEASE chime in...
              Cheers,
              Wade
              • well generally when things like this go wrong, we have to go back to basic's...
                Spark plugs?
                • how is the timing when it comes on boost?
                  Could it be something simple like a vac leak somewhere?
                  I spose you've already checked all that, but i figure worth mentioning.
                  HTH
                  • Wade, what diameter are the S3 fuel pipes, compared to the mk2s? It's not a volume rather than pressure thing is it? Hunt down the fuel flow figures and see if it is moving enough juice, cc's a minute, to the engine bay. Doesn't really explain why a slowly increasing throttle works OK, unless there's something amiss with the way the FPR is working.
                    • Hmmm. The vac lines i already replaced and also the plugs. The mk2 fuel hard lines are the same diameter and all the other things i've replaced are genuine OEM brands from work and AMK specific.
                      The timing is fine, and if I unplug the boost controller (n75) and run it at low (wastegate) pressure it's perfect - just 90bhp short! Seems to be only an issue when on full boost at max pressure...
                      • Sounds like a pretty maddening situation to be in! I dont know enough about engines to assist sadly. So long as its getting enough dinojuice it should be okay??? Personally I would try running a full S3 fuel system from tank to donk (if you arent already?).
                        • Originally posted by MattyT View Post
                          Well it pretty much is now...
                          I just spent an hour or so removing the whole fuel reservoir/external pump assembly from under the car and have now even fitted the S3 spec filter just to be super sure. So its basically the in-tank VR6 pump feeding directly to the filter, and straight up to the fuel rail, to the stock S3 injectors and brand new S3 spec FPR, then back around. Simple as, and still the same.
                          If I plug in the N75 and run it at full boost and bury the throttle, I can just hear it start to sputter as it spools up, at which point I immediately button off to avoid engine kaboomage.
                          With the N75 disconnected, its revving up beautifully and getting enough fuel, but feels gutless obviously due to the low boost pressure
                          So, that's it. Theres' nothing left it could be but the ECU....
                          • one point, which n75? n75J right from the s3? cos i've read alot about the splutting and surging with an unsuitable n75.
                            just trying to help
                            • Originally posted by Dscott View Post
                              just trying to help
                              Hmm, well it was the one fitted to the engine when I got it and is a genuine Audi part, but I'll get the part number off it and double check it in ETKA. Thanks!
                              • You've certainly got a curly one! Again, apologies if I've missed something earlier in the thread, but have you logged what's happening with the fuel pressure by tee-ing into the rail entry or somewhere around there? It can quite literally only be a fuel pressure and delivery issue now.
                                Have you flow tested and/or had the injectors ultrasonically cleaned? Are they up to spec (440ccm IIRC?) or is something amiss here?
                                Is the fuel rail blocked with dislodged filter material (rare, but have seen it happen!)?
                                Have you gone right back to basics with a noid light on the injectors to ensure accurate pulse? And is the wiring consistent to all four injectors?
                                What's happening with voltage to the fuel pump?
                                Have you back-probed the injector outputs to check for voltage/spikes?
                                Don't spend too much more on Bosch parts - I work for Bosch Automotive and can get them to you for a fraction of what you've have paid so far
