SG-TP-AB RS230 - Timeline
  • #46
    Ordered a JB4 for it, so should be good.
    Anyone know a good dyno place? Brisbane North side??
    Going to give East Coast Customs a go, their Dyno rate seems fair ($195 per hour)
    New Air Filter from Canberra VW Centre turned up
    Hope I get similar results as Ferret VRS
    Skoda RS 230
    "The Grey Ghost"
    • #47
      Did you order the JB4 direct from Burger Motorsports or from Autoinstruct? How much was it?
      MY16.5 Octavia RS wagon, manual, Moon White + tech pack + 18" black pack.
      • #48
        I ordered via Autoinstruct.
        I started a group but, so I got a better price, But I had to order 6 units.
        The Pricing on the Autoinstruct website is still very good. Get in fast as there is/was a sale on.
        The reviews I've read say its the best thing you can do for easy performance.
        Skoda RS 230
        "The Grey Ghost"
        • #49
          Yeah, I saw you were organising a group buy but wasn't sure if it went ahead or not.
          I've read lots about the JB4 on golfmk7.com but having a manual RS I'm concerned about my clutch. My wife is still pissed off about needing to replace the clutch on our last car so I'm not prepared to risk it yet on the new one. Perhaps when I've put aside enough money to pay for a TTRS clutch assembly (much higher torque rating) and the labour to install it...
          • #50
            Yea I'm hearing ya on the clutch, RS230 is manual only, so will only be 'tuned' when needed. It's a daily driver car so no need to stuff clutch going to work.
            Is that the thing do to do is it? TTRS clutch? That would definitely help!
            Skoda RS 230
            "The Grey Ghost"
            • #51
              I believe so, at least from reading golfmk7.com forums. Basically, you can put together a collection of OEM parts that include parts from the TTRS clutch. This is an alternative to getting an uprated after-market clutch, and they believe that some of those kits are doing the same thing (OEM parts slightly modified). One such highly rated clutch is the RSR Clutch from HS Tuning:
              HS Tuning RSR 2.0T Clutch Kit - HSTRSR1
              Here's the thread on building your own "TTRS" clutch:
              Official DIY TTRS Clutch Kit - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
              • #52
                There's also the Sach's clutch that reviews well, note that we get 19% off too being outside the EU:
                Performance Clutch from SACHS Performance, VAG OE 03G141015L. ✔ Audi, BMW and MB DTM Clutch Supplier - Trust in the highest level of motorsports expertise.
                • #53
                  Do you have any photo of the underside of your car? I'd love to see the difference in exhaust setup to standard so I can try to emulate in the aftermarket. The APR drop in 'turbo muffler delete' seems to be a lot off effort for little gain in value or exhaust note improvement. I'm looking for a little more noise without being rude. I think the RS230 achieves this but i'm not sure exactly how.
                  OCTAVIA 3 PARTS FOR SALE:
                  Brushed stainless rear bumper & cargo protector, Octavia III Combi models
                  • #54
                    From the other forum, RS230 has a smaller diameter cylindrical mid muffler as opposed to the prism like mid muffler on the RS220, length wise is the same I believe.
                    I don't believe the turbo muffler delete does anything in regards to the muffler note, its more for the noise of the turbo itself. I might be wrong here.
                    If you want improvement on the exhaust note, changing mid muffler is the easiest and cheapest way, I did and is very happy with the result. Find one that is steel packed and the longest you can fit there (OEM is 24 inch long). Newer RS has a band clamp around the mid muffler instead of one solid pipe, which makes things a bit simpler.
                    2011 Tiguan 125TSI - SOLD
                    2014 Race Blue Octavia RS 162TSI Combi
                    Check out my leather work ----> http://pedsnro.blogspot.com/
                    • #55
                      Briskoda has some info about the 230 pipes as well.
                      Skoda RS 230
                      "The Grey Ghost"
                      • #56
                        You might want to use a selfie stick or jack one side up to take a photo, it's very tight down there.
                        • #57
                          Around Post 21 28/39 has photos, 48 has part layout
                          My photos will not be that good.... as the car is in the air. in post 39.
                          How does the VRS 230 exhaust sound thing work? - Skoda Octavia Mk III (2013 onward) - BRISKODA
                          Skoda RS 230
                          "The Grey Ghost"
                          • #58
                            Mine photos will not be that good.... as the car is in the air. in post 39.
                            Thanks for posting that link, had a read through it all. Looks like the rear silencers have different part numbers also. It would be a big job to swap is all over to RS230 parts. Might try and have a look under mine to see there there is a slip join with a band clamp as per 99Reza's suggestion either end of the centre muffler. Id like to make is as easy as possible to put back to stock if it doesn't work out.
                            • #59
                              JB4 installed....
                              Awaiting the Lambda Plugs to hook up AFR, then off to the Dyno
                              Skoda RS 230
                              "The Grey Ghost"
                              • #60
                                JB4 installed....
                                So you're not happy with using the supplied PosiTap connection? Has anyone else come up with a workaround or are you the pioneer?
